AJ1978
Title says it all. Need some help on a VT 735 80 with 705 pump. I have been in contact with factory and dealer. I need some more insight and help with symptoms.
Came in Tuesday with compressor running tank was at 60 PSI and not pumping up. Checked all the obvious. Called my distributor, he told me that he felt it was valves. This unit was placed in service 6-29-15 so 18 months of mild use.
I talked with saylor beall and the dealer and they thought perhaps an intake valve was bad.. so sent me a full valve kit and the tool over night at $$$ so installed them, all 5.. same symptoms, put a gauge on the intercooler not making over 10 PSI.
Saylor beall is sending me a head, but I fear this issue is deeper, I notice oil on the bolts holding the intercooler to head, as well as rust, top of HP piston is rusty.
I fear rings are out of it when it runs the head gets warm and it puts air out but I can stop it with my finger.. well the air flow that is
