School me on Load Capacity
PMAC
attached to house in MN
We have a new air compressor that weighs 815lbs and the footprint is 6.5ft x 2ft. The placement of choice is on the roof of a grinding booth that has a load capacity of 45lb/sf. What type of calculation do I need to do to determine if this is an approved placement? What advice can you give me? What should I be asking?
Dustball
Hudson, WI
Also the compressor is most likely going to be unevenly balanced so you can't simply divide the load placed on the feet evenly.
Can you install channel iron to distribute the load to the corners of the booth?
matt_i
I wold use ERW box tube (electric resistance welded) or an I-beam.
Channel deflects in a twist with flanges-horizontal and very floppy in the I-yy direction with flanges-vertical.
You can work around that by going back-to-back and forming essentially an I-beam or going very heavy to work flanges-vertical but that's more steelwork than doing it with tube or I-
Something like an S4 x 7.7#/ft would be good for your load without doing any calculations.
If you did go back-to-back with channels welded to spacer tabs then there's the nice feature of having an instant slot to drop the threaded rods thru, with which you will secure the feet.
It deserves plenty of attention due to the risk factors of: overhead load and the guaranteed vibration and the propensity for people to be working underneath.
Strong gussets to legs all around, 7018 stick welding clean metal, torque prevailing (deformed-thread) locknuts, and bolt the legs to the concrete.
P
PMAC
Yep, I work in a fab shop. We are now building a platform to bolt it to before it goes up above the booth to distribute the weight more. Thanks all for the info.
whateg01
doo dah, kansas, usa
You don't just need to distribute the load more. Depending on the structure of the walls you may need more vertical support too
