ScaldedDog
I bought a 5hp, 80g Eaton a couple of years ago, and it's been fine. The only thing I don't like about it is that it came with a 150psi pop-off valve, even though it claims to be a "175psi" compressor, and the tank working pressure is 200psi. I replaced the pop-off with a 200psi one tonight.
Anyway, there are "things" on the top, that I don't understand. Care to take a look at the photo below and school me?
Top center pop off valve, facing right - What does this do, and does it have to match the psi rating of the one in the tank
Brass fittings with splined knob in lower center - What is this? Does it need any adjustment if I change the tank pop-off pressure?
Valve at lower left - I assume this is just an oil drain?
"Bolt" above the valve - What is this? An oil fill plug? It seems rather elaborate for that. There are 5 holes in the top of it, with what looks like a ball down in one of them. ??
Thanks for your expertise.
Mark
Mark
