JRC3
I'll just leave these pics of those jackstands here...
Semi-related: for those of you who've used one a bunch, is there an obvious way to tell when it's reached max height? I don't think I've gotten there yet (I have a flourescent light I need to hang higher), but does it simply peter out or does it hit a stop?
I just realized you have the exact same lift as I do except mine was made by Hanmecson before Rotary bought them to sell under the Revolution line. Rotary did beef up the safety latch pin diameter a tad bit in the process.
Your're joking, right? I've already mentioned other reasons on their use. Like supporting the vehicle and lowering the lift to drop a RWD transmission. Exhaust work. "Other than brake work." You can use the stands to do everything you'd normally do...Just safely. And actually be able to do more than the mid-lift's capabilities.TBH, other than brake work, I cannot see the advantage of those stands, to short to stand under car.
I'd be afraid of damaging something by running it til it stops. Why would you want to go so far past the last safety catch anyways, even with a set of jackstands. I've considered painting that area just past the last catch orange so I know I'm there.
