Sealing Floor
LivenLife
Oklahoma
I have been searching the forum for awhile now and I would like to get advice from the experts. I have a 24 x 24 red iron building with a 6" slab. There is no vapor barrier installed under the concrete and they used a power trowel to finish it. I am looking at sealing it because I will be doing some welding and metal work. I have read through the different threads and would like to use the densifier with Ghostshield 8510 that was mentioned. I would like to see if this would be a good option for me and see what is best way to apply it. Also, I have white liner panels around the interior walls and would like to know if the chemicals will eat any of the paint off if it were to come in contact when applying. Thanks.
Shea
California
Use a pump up sprayer with a cone nozzle for both applications. If the densifier begins to puddle, you can use a push broom to move it around. GhostShield is now saying that one flood coat is all that is needed over the densifier. Just apply it with the sprayer until it begins to puddle on the surface. Neither product should hurt the paint, but it would be wise to tape it off with plastic first.
Garage Flooring
Grand Junction, CO
What he said :thumbup: Just make sure the sprayer is chemical resistant as 8510 is solvent based
L
LivenLife
Oklahoma
Justin,
The Lithi-Tek 4500 is what is reccomended? And I want to make sure I order correctly. 1-gallon Lithi-Tek 4500 and 2-gallon Ghostshield 8510 for 576sq. ft.?
Thanks
Armorpoxy
Hi,
We recommend the 4500 Densifier along with one flood coat or two lighter coats of the 8510. Makes for a super fluid-resistant floor, and easy to apply, and not affected by welding. These products should not affect a painted surface.
Alternately we offer a nice inexpensive solvent-based sealer that can be pump sprayer applied. We have used this in firehouses with superb results. Please email us directly at below for info and pricing.
Thanks.
man00
I have a question that may sound dumb but most sealers protect against water only ..correct? If that is the case why waste the $$ sealing if the concrete has a roof over it? Mine is just a pole barn 30x30x10
Armorpoxy
Incorrect, many sealers, especially the Ghostshield System protect against oils, spills, and other fluids from penetrating and ruining the floor.
dusterdude
If i may hijack a bit,will this work on a wood floor or is there something else i can use to seal it that is petroleum resistant?thanks
Sent from my R1 HD using Tapatalk
Armorpoxy
Hi
We offer flexible epoxies and topcoat that can be used on wood floors. That being said if the floor panels expand and contract from temperature or humidity you could still develop small cracks which are easily touched up. Unfortunately there is no solution for that other than going to a membrane type traffic coding which is extremely expensive.
Please contact us directly at below for information and a quote so we can get that to you promptly. Thank you very much.
L
LivenLife
Oklahoma
One more question. I received my Ghostshield today and am going to clear out the shop to start coating. I believe I need to apply the densifier and wait 7 days before applying the Ghostshield. How long after I apply the densifier do I need to wait before I roll stuff back into the shop? It's not vehicles or anything large, just a few items on furniture dollies.
rd65
Granite Falls, WA
Ruining or staining? I just built a 28x32 w/ 4-4.5" slab w/ fiber concrete. what is the purpose of sealing the floor. is it necessary or optional?
Armorpoxy
Staining and fluids getting into the floor affect it cosmetically. If you live in an area that has winter and road salt then the floor over time could get severely corroded from road salts hence why to protect it. Also oils and such leaching into the floor can make it slippery since it’s hard to clean.
