volleyball
!/2" 100' line and couplers for $78.02
There is a shop your way $10 off coupon you can apply for $68.02
Has anyone used this stuff? Is the tubing the same size as pex? Could you use pex pipe if you had some and needed more to make this kit work?
After a quick google search, it looks like 1/2" PEX is 5/8" OD, so it won't work with the push lock fittings.
