Seeking decent air regulator and "filter"
HyperPete
Not far from Gettysburg, Pennsylvania
I'm running my compressor lines and I think I want/need to replace my air regulator(s) and water traps.
I used 3/4" black iron and a stainless 3/4" flex pipe from the compressor and for the first 6 feet with a down leg to collect water, and then it switches to 3/4" Maxline. The outlets at the end of each line reduce to 1/2". My older filters and regulators are 3/8" and 1/4". (Both regulators are 3/8".) My air hoses are 3/8". I am thinking that I want to dump AT LEAST the 1/4" filter, and possible upgrade the regulators to 1/2", although I am unsure that this is necessary since my air hoses are 3/8."
The first regulator is a 30 year old Stanley Bostich, and the second is a cheapo Kobalt. I Just replaced the Kobalt under warranty because it leaked constantly, so I can return the unopened product if I want.
The compressor is a 60 gallon 230V 2-stage Kobalt that's made by Campbell Hausfeld, which I picked up on sale. I will be using it primarily for my air tool (impacts, ratchets, drills, cutoff, grinder/sander, etc.) I might use it occasionally for my modified Harbor Freight 20 gallon sandblaster and eventually some small motorcycle painting products, but I will add a dessicant before I start painting. I understand that the compressor is not ideal for high CFM work like sandblasting, but for the occasional use I plan, I will make do.
I am retired, and the work I will be doing is as a hobbyist, so I do not need something designed for professional use, but I am a firm believer that "the bitterness of low quality remains long after the sweetness of low price is forgotten." Therefore, I am looking for your suggestions.
H
HyperPete
At first the link did not work, but I figured it out - the trailing bracket is not included in the link for some reason.
These are very reasonably priced. Thank you for the suggestions. Tomorrow I should find out if the old Stanley Bostich regulator even works. I took it apart and cleaned it and see nothing wrong, so it SHOULD. I will be returning the Kobalt regulator. I just want something better, and hopefully more reliable.
matt_i
SE Michigan
My take is to use used industrial components.
Norgren, Numatics, Master Pneumatic, Aro, Festo, are just a couple I can think of currently, the list is probably triple that.
Check ebay for something that looks clean on the outside and not hacked up.
H
HyperPete
If you want to spend more money for proven quality, here's a vendor for SMC-
https://www.smcpneumatics.com/Part-Builders-FRLs_ep_2427-1.html
Wow, those look nice! I think the series AC will work fine, and are not unreasonably priced.
Thank you for the list to check out. I don't think I want to deal with something used, I'll splurge a little on this for the peace of mind knowing I won't have to deal with possible defects and returns. I think I will just setup one outlet for now, and add to the setup as needed
stonesfan68
Houston, TX
I second this suggestion. I would add Ingersoll-Rand, Hankison/SPX/Pneumatic Products to the list.
sberry
Brethren, Michigan
I just happened to look at Walmart, had the ideal sized stuff right on the shelf.
I have had a couple cheaper ones take a **** but they were old and wellllll used. It was time to redesign anyway. 25 years. I like the 3/8 stuff, most of the regs have combination ports, 1/4 for gages.
sberry
Brethren, Michigan
Pic 3 was a salvage, 4 is just ahead of the paint reel. 1 and 2 are to a single reel, the stuff is old, I usually shut off the valve.
This shows the plumbing in to that unit, valve ahead of the union. I had a whole bunch and pile of fittings at hand and losses from more fittings irrelevent.
MAYOR28
Southern MD
I just bought a PneumaticsPlus unit for my install. Been using a small 1/4" version without issue for about 8 years, upgraded to a 3/4" inlet for my new compressor.
AMAZON LINKY:
My layout and build out: THREAD.
H
HyperPete
This is what I have at the moment. The Kobalt filter is supposed to filter down to 5 μm, and the Monnier (on the right) can filter to 3 μm, but has 1/4" fittings. I still have to finish running the air lines, but I have to go get some insulation first so I don't keep ******* through propane so fast trying to keep warm out there!
The nice thing about retirement is that if I don't get it done today, I can work on it tomorrow! :D
g6OtcU6lRFqciqqk0fV9AA
sberry
Brethren, Michigan
All these threads run together. We talk about whats the use and the placement of hydrants and reels needs to consider the landscape. A big use for many most on this forum is likely tires and nothing as good as a reel reaches out around a car on the apron etc. My Bud should be a 2 reel shop, basically one at each end. Reaches all the way out on the apron for tire service.
The first 2 pics above is one of my faves. I relocated the line about 6 ft, was a super pain to get to the valve replumbed it with a 1/2 valve on the hard line, a reducing bushing to a 3/8 hyd swivel 90 degree then a hyd ****** to 3/8 npt in to the filter, 2/8 nip to reg and used the 1/4 90 that was salvage at the moment to ****** up. Any improvements I can or could make irrelevant and minor.
H
HyperPete
Yep, understood. Tire service will be included in my needs, including tire removal, replacement, and bead seating, mostly for motorcycles, but I have had to do so on my truck when I needed to install pressure sensors on my snow tires / rims.
I'll be sandblasting occasionally, which needs a lot of volume; likely more than my compressor can easily handle. If I find that I am doing it more frequently than I suspect I will, I can always sell this compressor and upgrade into something more powerful. I suspect, however, this one will be fine.
I have never done automotive painting, but I am likely to give that a try in the future. I realize I will need to add desiccant prior to doing so.
I just installed an overhead hose reel yesterday, and that is likely going to be my main air source. I have a couple of ultra cheap Harbor Freight manual reels, and I may or may not run lines for those as well for the times I want to use multiple tools or have other folks visiting and also using the air. (Think tech sessions.)
I realize that what I am doing is overkill, but what the heck - why not? In the past I did not have the wherewithal to be able to do this, and I'm not going to live forever, so why not go with overkill? ;)
