Seeking Small Hex Bit Ratchet
Bolster
Mexifornia
I'm looking for a quality small hex bit ratchet. Need it for tight clearance situations. Suggestions?
This is the one that has caught my eye:
https://www.amazon.com/gp/product/B07F42ZF9B/?tag=atomicindus08-20
I already own one like the following, unbranded, no great shakes, but it does the job, just wanted to upgrade:
https://www.toolsource.com/14-in-dr...-drive-hex-bit-ratchet-w-handle-p-106154.html
...and since I haven't haunted GJ for awhile, what happened to the GJ image hosting, and what low cost source do you use to post your images these days? It's a lot more fun to post images than links...
Bigblue&Goldie
This is one tool you want to make sure has super light back drag. I have a SnapOn (bring on the hate) and it's been worth every penny. I bought it on ebay for ~$60. Best tool ever for assembling Ikea **** and kid's toys.
TonyJ
West Virginia
76d13bb14af157d1dab6f1206c21f95e.jpg $11 on eBay. I’ve had one for close to 10 years and lost it and bought another one last week. I use it more than a 1/4 regular ratchet by using a 1/4 bit adapter
Luciferi
I have then Titan flex head. It works great and wondered why I didn’t get one sooner
KnurledNut
n/a
Bolster is back!
:beer:
Both of the ones you linked, and the VIM someone else posted (and many other brands) all have Reverse Gear brand mechanisms. So you wouldnt be gaining much over what you currently have.
On the pics, just link the URL using the picture button when posting.
RKA
Same one made by EZ Red? I have a full set of VIM bit ratchets and that’s my one gripe with them. Too much back drag considering how and where these are intended to be used.
pedalwrench
I have the presta cycle thing n I love it, mostly because of the ability to turn it into a t-handle. It's designed as a bike tool and that's a very handy feature in that application. I haven't seen another bit ratchet that does that, so I'm a fan.
Sent from my moto g(7) power using Tapatalk
JBH
I have the flex head version of the Koken as well as Felo, Reverse Gear, Stahlwille, Anex, and Wiha.
Koken is by far the best in actual use. Felo is a distant 2nd. The others have their place; the tiny headed Reverse Gear for USAG/Facom locking flex is sometimes more useful than full sized Koken for example.
Bigblue&Goldie
The one I have is essentially the 1/4 Dual 80 (72t) ratchet.
M6erfan
'Merica!
My favorite is the MAC MR5bd, unfortunately no longer made. I have 3 of them. I also have a Snap-on, and it's okay, just longer handled. I use it for more leverage. I bought a Koken flex head 5/8" for heavier work, and it's well made. I have a long handled EX red, and it's mediocre. But long handled.
Buying new, I'd recommend either the Snap-on or the Koken. The difference between them is the Koken has retaining ring for keeping in the bit, the Snap-on is magnetic. Both have their advantages.
MAC website shows it as available...
https://www.mactools.com/en-us/Ratchets-and-Accessories/1-4-Drive/MR5BD/1-4-Mini-Hex-Bit-Ratchet
nbpt100
Massachusetts
I have a 25 year old Sears brand. Nothing fancy and I hardly use it so it is fine. I recently needed a very low profile so I bought a 1/4 ratcheting box wrench and cut the bit down to minimum length that would work. I needed to be careful to not let the bit fall out but it worked to get the screws removed.
If I were to buy a new one I would look at VIM or the Koken that were shown above.
ihateminimumwage
They're actually listed as in stock by MAC again, but with the $55 price tag, I've been doing just fine with the VIM that TonyJ posted a picture of.
bonneyman
Desert SW
I have a Reverse Gear clone that works very well, and the cheapie one offered by Craftsman has turned out to be pretty decent as well. For $11 and change it was definitely worth it.
TonyJ
West Virginia
Autozone used to carry one I think was branded as Titan that was the same as the VIM one but I haven’t seen it there in a while. The one I posted a pic of is my new one and my old one which is now lost I took apart and shortened the spring in just by one coil and gave it allot less back drag and it made it much better
CGarage
United States/Switzerland
That's a cool looking ratchet. I notice the kit with bits is only $10 more.
The bits are phenomenal and the tool is a lifesaver. 72 teeth in the mechanism also. I believe it is the smallest on the market. I have both the fixed and flex head versions. The flex head was released a few years after the fixed head.
madmanc
england
i have glued a penny to the top of a hex and used a ratchet spanner to work it for a tight space once , you can do a google search theres loads of tiny kits for these jobs , bahco being a very good one that i can recommend
Mr_John
I was looking for the same thing and bought a TONE 1/4 open ratchet set:
https://www.ebay.com/p/1086659269
I bought this as well, a Koken 1/4 mini ratchet, along with a 1/4 to 1/4 anvil to bit socket:
https://www.ebay.com/itm/Koken-Stub...522007?hash=item25acd66657:g:zYsAAOSwq6Nb1MUb
Both are great for low clearance areas. The TONE ratchet is nice, but the if the Koken fits, it has extremely low backdrag when you're trying to avoid the bolt backing out. I also have a set of GearWrench stubby Torx sockets, with a set of stubby VIM XZN triple squares on order from Zoro for those extremely tight access areas where the Koken will actually fit (vs the TONE).
CGarage
DSLTRK
PHELAN, CA
$15 at Oreilly auto parts. Comes with the rare 1/4" hex-square adapter.
Bolster
Mexifornia
Well! I can see this is not going to be a "buy one" sort of affair, it will require a collection. Thanks for pointing me in excellent directions, folks!
I am partial to the "passthrough" types, where the hex hole is broached all the way though, since that allows really low profile access. (I have even cut down hex bits in length for minimum clearance issues=too radical?)
JBH
If you’re looking for absolute minimum clearance I think the set to buy is the Würth one with the 11mm outer hex through sockets (compatible with Wera, Snapon, and Matco, but not the garbage set Astro Pneumatic sells), low profile bits, and dual 1/4” hex/11mm ratchet.
I think Matco and KS Tools have similar sets.
ZRX61
Solar Blight Valley, SoCal
I have a Sunex that's barely 3in long & a GW that's 1/4in on one end & 5/16 on the other. Both came with a few bits & the GW has some 1/4 drive sockets.
