Self-leveling concrete over old foundation (or something else)?
lukeiam
Hello! I've searched lots on this forum before posting this, so forgive me if it's already been discussed and I've missed it.
I have a 20x20' outbuilding on my property that's very well built (the inspector loved this building) with old lumbar, solid roof, etc...The issue is the floor is ****. Very cracked. The structure is plumb, though.
I noticed this year that the bylaws are allowing accessory dwellings in my neighborhood (I own a duplex and live upstairs). It's been my idea to convert this into a low-cost dwelling for myself (I'm single, no kids, etc) by pouring a slab off the back and attaching a 20x20' structure so making the total 800 sq ft. But I'd love to make this garage floor usable without tearing it down because it's quality lumbar. The floor is old, no doubt covered in oil and probably toxic stuff I'd love to encapsulate (fine for a garage but not a "living room"). Of course, I could raise it and pour a new foundation but that seems pricey. In truth, I don't care about cracks or imperfections -- many of the old mills here have amazing spaces with epoxy and cement poured over the original foundation for bar spaces, etc. Of course, the plumbing, etc, would be in the back *new* section over a modern slab.
Any advice would be welcome -- self-leveling concrete maybe? Or another option? Or it's hopeless and I need to just accept tearing it down or keeping it as a garage like this. THANK you!
RivennHewn
PNW
In the last pic, it looks like the walls sit on a fountain, and the slab is poured up to it.
If true, you could remove the slab, and pour(place) a new one without touching the building.
L
lukeiam
That's really interesting...I could take a few better pics of that later. I didn't realize that...I'm a decent weekend carpenter but know nothing about concrete (why I'm here!). It would be a lot easier to tear that out and pour something new, even if it didn't come out beautifully (I'm not working on old cars in here).
billconner
Thousand Islands NYS
Are you adverse to installing sleepers and subfloor over slab? Would seem simpler.
Personally I'd like to raise building enough to set it on new pressure treated sills, but that's me.
L
lukeiam
Got some more pics for you...Looks like it is sitting on a fountain (not sure what that is) on all 3 sides....So perhaps tearing out the rest would be doable and I wouldn't have to lift it.
RivennHewn
PNW
I think your best bet would be to have a contractor look at it with you, and give you a price. You can talk about scope and sequence of steps with someone who’s actually onsite and looking at it in person.
What you do after that depends on you and your budget, but at least you have experienced eyes looking at it.
dfiler2
NW Minnesota
That garage was probably built with a gravel floor, very common years ago. A skidsteer would make short work of tearing out the old floor. To me the challenge will be adding on to the back with the roof that building has. To do it right you will need to tear out half of the existing roof.
L
lukeiam
Thanks for the input! Yeah, it's from the 1920s...It's possible the garage was built later, but looking at the lumbar, I don't think so as it matches the home, which is very well built.
And agreed about the roof...otherwise my drainage will be a bit of a nightmare. I think the question has become whether it would be easier to just junk the whole thing. Sure, the wood is nicer from these older outbuildings, but ultimately it's maybe $4K in 2x4s, at best..The siding would need to come off and if I'm tearing out part of the roof, then the argument to keep it starts to go!
budget76
since there's smart guys on here and it made me have the thought - in a situation like this, IF it were a full slab and not foundation + later poured interior floor, is there any reason you couldn't do the following:
1. slice the interior floor along the walls, call it 3-6" inwards. leaves a "foundation" for the walls
2. rip out the interior floor concrete, however works.
3. drill a bunch of holes into the "foundation" and tie in rebar/etc
4. re-pour the interior floor like I see done for pole barns & such
doesn't sound too tough on a 2-car. a rental walk-behind saw would let you slice the whole interior floor into moveable 2x2' - 2x4' pieces, you could remove them in big chunks, and you'd be ready to prep anchors and lay out a grid for a re-pour within a weekend
NUTTSGT
Northern Central Ohio
I would tear the old concrete out and pour new, along with a curb (or lay a course of block) to fill in the door openings. It may be necessary to demo part of the floor for utility work, plumbing/drain lines.
So have you considered the availability for the utilities to this structure ? NG, electric, sewer and water ?
L
lukeiam
My plan is to build a small addition off the back over a modern slab, maybe another 10-20 feet, and have plumbing under that...No NG as it'll be a mini-split situation, given the size. So this structure I just want to be nice enough and have an updated floor that isn't all this old oil and ****. But, again -- I don't need a perfectly flat pristine garage floor (I know that's not in the cards). Like I said, not rolling trays of $4K tools around to work on cars. No cars will even be parked in here, but I'd likely get an insulated garage door just for a cool effect and all that light.
NUTTSGT
Going to leave both doors or just one ? "all that light" ? when you open the door or a glass door similar to an old service station ?
I would rip out the concrete, it's not a huge floor and if you try to clean all that **** off, it will probably be more of a headache that just ripping it out. If you repour, at 4" thick, it's just under 5 yards and you could put some foam board under the new pour to assist in keeping the slab warm.
L
lukeiam
That's a great idea...Yeah, my thinking was one garage door..insulated. They're pricey, but it would be a very cool look and effect for summer or warmer days. I have a buddy who converted a similar space into a bar and kept a door like that and it's gorgeous. I'd have the primary door in the newer section. This whole thing is tricky because I'm trying to do this in a budget, otherwise it'll never recoup on the "accessory dwelling" aspect. So not lifting this and repouring would save me a bundle.
I REALLY appreciate everyone commenting here and helping me out
brownbagg
new concrete on old always cracks, but....... they make a membrane that would seperate the old from new and then four four inches on it. elevation a problem..... jackhammer
L
lukeiam
I've busted out floors like that with a sledgehammer (when I was younger). It doesn't take very long but ya sure feel it the next day.
Well, I'm between older and younger so I might just be up to the task if I were to break it up over several days...Also, good to know about just using a Jackhammer.
But as others have said, seems like getting a Pro in here is the way. But this thread has made me hopeful for doing this job without having to jack up the structure.
flat350
illinois
When we did some work in a Wrigley Gum factory in Chicago they had topped the old slabs with 2" of sand and poured new concrete over the top. Forklifts and all kinds of traffic on them and they all looked good, didn't even know until we started sawcutting for new lines in the slab.
75gmck25
Alexandria, VA
It seems you might not be that familiar with the construction techniques they often used in that timeframe.
They probably dug out for footings to support the walls and then either used cement block and/or poured cement to provide a base for the walls. Then they framed and built the walls on top of the footings. The cement slab was poured later and it floats in relation to the walls - in other words its just thick enough to support a car parked there. Its probably 4"-6" thick and can be broken up with a jackhammer relatively quickly. It also has no insulation or vapor barrier under it.
If you remove the slab you can then install foam insulation and a thick vapor barrier under the new slab. This will make the room more comfortable, and you won't be fighting moisture coming up through the slab. You could probably get similar results by leveling sleepers on the current floor and installing insulation. vapor barrier and flooring on top, but you will lose headroom and the inside floor will be higher than the garage apron outside.
Leaflessshadetree
Don't ask.
If it's just cracked and the sections are even I'd leave it. Cutting/busting it all out is a good idea. Compact the base before you repour.
I've also helped do one where we cut a trench about a foot wide (both sides of the crack). Drilled and inserted rebar dowels then poured to fill. Ended up with 2 joints 1ft apart.
Uncle murph
Harford county
I’m willing to bet that floor is a super economy job,probably not more than 2” thick,easily broken up with a maul.Smack it a couple of times in the corner to verify.
CraigStu
Blacksburg, Va
Could you build a wood floor over the concrete? Thinking some kind of paint on the concrete first to seal away odors etc from the **** dripped on it over the years and then a standard floor. Laying 2x4s on edge, using shims/glue to get them all level on the uneven concrete, standard osb sub flooring screwed/glued down, and there is your standard floor. Have you looked into codes to see if you will be allowed to do this yet?
L
lukeiam
Thanks! I think I wanted to get a better idea of what this job would entail before contacting local gov't, especially because doing so will raise my exposure somewhat. EG, if I'm just repouring a floor and adding insulation, I'd probably DIY this and leaving permits out of it. BUT if I'm trying to plumb it, add electrical, etc, then I really need to make sure I'm in code.
My concern -- and I would need to talk to a specialist -- is that this kind of foundation wouldn't be to code for plumbing, even if I dug down, because it's not a modern slab (eg, the footings)...Anyone in MA have experience with this? I'm basically, for all intents and purposes, adding a bathroom to my garage.
Really appreciate all the help here!
L
lukeiam
Are you familiar with any DIY content to get this done? It's a small enough space and I don't need a perfect-looking slab as this will be a workshop...I could demo and hire out, for sure, but if this can be done with a few friends, I could attempt that. Thanks!
Greg5OH
Would adding an uncoupling membrane be ok, like SHluter Ditra? coudl also do ditra heat and have heated floors. The point of these membranes is to isolate (usually) tiles from any shifting, flexing or cracking in the subfloor.
I used it in my class A RV, with 12x24 tiles over top. 3 years no cracks yet. I imagine a non mobile structure would be even better.
