self leveling polyurethane
michaelf
SE MI
Has anyone here used self leveling polyurethane to fill concrete expansion joints and have any hints or advice?
gregtwojeeps
Ky
Yep, used this for years at work around the pool and just did my patio/drive expansion joints last summer. Good stuff and comes in 12 or 20 oz. caulking tubes. Pressure wash the cracks, let hem dry, use a caulking gun to slowly squeeze in the caulk for joints that may slope too much too quickly, as it will run out of the crack as it levels. ...
If steep grades are a problem, the Sonolastic/Basf NP1 which is not self leveling, works well too. If your gun skills are lacking, it is good to line both sides of the crack with blue painters tape so to not get the caulk outside of the crack.. it is messy stuff and hard to remove. JMO
th
M
michaelf
SE MI
Thank you for your reply, it is my driveway I need to do as the joints seen to be getting much wider
