If they worked then thats great!I am sure I will get flamed for this, but these from HF worked well for me in fabbing some benches and an auto body rotisserie.
Silver And Deming Drill Bit Set, 8 Piece
Amazing deals on this 8Pc Silver & Deming Drill Bit Set at Harbor Freight. Quality tools & low prices.www.harborfreight.com
I have that set..... I purchased it in roughly 2005 or 2006 from HF. I have used that set heavily while doing several metal working projects over the years and other than bending one bit (used in a handheld Milwaukee Hole Hog) the set has held up well. In fact I just used one of those bits a few days ago.... still worked great.I am sure I will get flamed for this, but these from HF worked well for me in fabbing some benches and an auto body rotisserie.
Whether you purchase a cheap set or a good set, take some time to learn how to thin the web on your drill bits. It will make your drilling experience much more enjoyable. Check youtube, many videos on how to do it. If you choose not to thin the web, drill a pilot hole the same size as the web thickness.I need a set of deming bits (9/16" - 1") that won't break the bank. Experiences? Thanks! M
Milwaukee® S&D Black Oxide drill bits are designed for extreme durability and long life. A specially designed parabolic flute form clears chips fast, while the 3-Flat Secure-Grip™ shank holds the bit firmly in the drill chuck. The 135° split point tip delivers a precision start and prevents walking for fast, accurate holes.
I had to do a serious doubletake to figure out what was attached to the end of your drill bits.I got a super deal on Butterfield bits about fifty years ago, had a friend working there. Added one extra that I needed along the way. Got the 29 piece set too, in the index box.
Ouch ! $254 !This set has been good to me: https://www.harryepstein.com/norseman-8-pc-premium-black-gold-moly-drill-bit-set.html
American made drill bits. You pay for what you get, maybe search around you can find them cheaper.........Ouch ! $254 !
You know, this is really a great discussion forum! I appreciate all the responses! I ordered these guys: https://www.ebay.com/itm/171709553029 (made an offer [hint]). M
Yeah. I just saw that video. I have ordered the M7 set (offer taken). If they arrive all jagged, I'll try to post some pics here (if that's permitted). mGood luck with it, if you win it. They aren't the highest of import quality.
https://www.garagejournal.com/forum/threads/alternative-us-made-drill-bits.436858/
https://www.garagejournal.com/forum/threads/drill-hog-warranty.405652/
https://www.garagejournal.com/forum/threads/drill-bit-set-recommendations.451096/
I'm very curious as well, because when they first started out Drill Hog was putting China made drill bits into US made Huot drill index cases and then using them as justification to add "US made" to their listing titles. The "Made in America" sticker you see on the inside of the bit index and stamped on the index front in their photos refers only to the metal index itself not the bits in the index. Then they named their company "Drill Hog USA" and put their business card in their listing images so you would see "USA" everywhere you look, but nothing ever mentioned where the actual drill bits were made.Please do. I would also be curious if they have USA on their shanks. If you remember, could you let us know on that as well.
Thank you for posting this video.Good luck with it, if you win it. They aren't the highest of import quality.
I have to disagree, have drilled hundreds of large holes with a Bport @ 60rpm in back gear in CR/HR steel and the holes come out very nice without chatter and the edge tools last a long time. In the lathe at 110rpm in W1 (annealed) tool steel. As opposed to even using a 20" DP at its minimum of 300 rpm, the holes will come out chattery. As suggested earlier drill a pilot hole so the center web doesn't have to rub around material which just creates heat that's detrimental to the rest of it. The 100sfm charts are from 1920s industrial engineers who were trying to figure out how many horizontal mills they had to order to run their factories at rate. For example 100sfm = 1200 s-ipm. Your 1" dia bit has 3.14" of "surface" and so you divide that and come up with 382rpm which I regard as screaming. If you are paying for your own edge tools you will learn via your wallet you don't have to run them at warp 9 unless you are chasing actual profits. Resist the temptation to get 135 degree S+D bits (which cost extra and might seem "premium") as they don't follow a center hole worth a darn and you get low quality holes that are chattery at first until the bit starts piloting on the OD. Also super easy to break the razor sharp center and then it rubs even more.They'll probably be ok, but the last two pics appear to show a lack of quality in sharpening.
also, everyone always says, "drill slow". But it's really "drill at the proper speed". If you try and drill a 3/4 hole in steel with a bit at 150 RPM you'll go ~nowhere. Too slow can equal zero progress. There are charts and formulas to determine the correct speed. Obviously using a hand drill you'll have to guess, but if you have a drill press...
