Good Morning,
I'm in the process of building a house and shop and want to get Cat cable run through the house before the insulation and drywall start going up but I have a few questions.
Should I run cat 5 or 6 cable?
I plan to run 6 cameras at the house. One at each corner on the soffit and one at each door.
For the soffit cameras they will be about 40ft off the ground so looking for recommendations for those cameras. I've read alittle about 5442 Dahua series cameras and heard about Hikivision cameras as an options for better than entry level. These would be near a flood light if that makes a difference. Flood lights are switch operated at the moment but would be updated to motion sensor.
The garage will have soffit cameras as well but those are only 12-13ft off the ground and I have one by the entry door plus inside. My goal is to have two separate systems with their own NVRs. I'll be able to run internet from the house to the garage and it's about a 60-70ft run.
I'm interested in being able to view these without them dialing back home to China or whatever countries servers they came from. Which systems can that be turned off on?
Look forward to hearing what you guys think and if I'm missing something.
Thanks,
Magna
Thanks,
Magna
