bulletpruf
It ain't all that much about fancy to start with but convenience, can you get around etc, a few place to set something under. Simple top spills won't go thru, huge doesn't matter as you ain't gonna build trailers on it anyway. 99% of my stuff is small and couple 3 pieces or a weld.
For a lot of guys once the place is built the welding use goes down.
The work is on the car or machine.
The use is multi purpose.
If I just use it for welding/fabricating, I think you're right -- it's fine. I just need to use my toolbox tops (6' long with stainless steel tops) for my general workbench and project area.
That's a great looking little table. I'm sure even if you outgrow it, you'll still keep it around.
When you're ready for that 30x60'', check out the link to my build below.
Glenn
Thanks, Glenn. I think it would be great to keep around as a portable table that I can wheel outside. Just needs casters.
