Severe pitting on concrete floor
CTC DEEZUL
Indiana
Converting my 1.5 car to an office. The concrete is pitted.
What would be good to lay down to smooth it all down so I can either vinyl plank or epoxy coat the floor?
Thanks.
Mikes61
I used Quikrete Structural Repair to fill in some holes, smooth out my stemwall and float my slab where I removed part of my stemwall.
It’s a powder that mixes with water. Available at Home Depot or Amazon. Be sure to follow the directions about wetting your existing cement first.
FJ4FUN
NorCal
What you choose to use for filling the spalled areas will depend on what you choose to do afterwards. If you go with any sort of laminate/vinyl plank then any cementitious patching material will be fine. If you intend to apply an epoxy you'll need to patch with an epoxy based mortar.
Garage Flooring
Grand Junction, CO
We sell large repair kits for areas like this BUT it would be overkill if you are not doing a coating. garageflooringllc.com/product/concrete-repair-materials/
