Sewage pump/pit
alex2929
I have been Debating if/how about putting a bathroom in my shop. I do not have enough fall to get it to my septic system naturally so I would have to have a pump. A guy I know recently had a pipe bored in and has a little pump in his shop. Anyone have any thoughts, opinions, ideas? The bathroom would be roughly 100’ from my septic.
micromind
Fernley, Nevada, about 30 miles east of Reno.
I've seen this/done this more than a few times.
With a 2" discharge pipe, you'd need a grinder pump. These are not very good, in my opinion. Especially in a shop where dirt, silt, gravel, etc would get in to it. They can't handle stuff like that and will fail fairly soon.
A solids-handling pump with a 4" pipe is much better. A properly designed and installed system like this can easily last 30 years, often more.
With just a shop, there's no need for a duplex (2 pump) system. A single pump is much less $$$ and when it fails, simply don't use it until it is repaired.
Renegade1LI
long island ny
A sump pit with 2" sewerage ejector pump should work fine, in 20 years in my basement I have only replaced the float once. Tried and true technology, keep it simple they just work.
