Share unique tools others may not know about
signcrafter
Thought this might be a fun thread. I posted about a tool a pretty unique tool a lot of people might not know about in another member's thread earlier today. Sitting here tonight got me thinking there are probably a lot of tools out there that I or others may not even know about that may be something we could use. Not so much old or rare tools but more so tools that someone may not know exist unless you do that kind of work. Could be trade related or auto repair or whatever tool. I do a wide variety of work and run into new things all the time and I'm all about getting tools that make the jobs easier. But sometimes you don't know about a tool if you aren't around that kind of work.
Two examples I have are a backer rod insertion tool. Used for putting backer rod in the saw cuts in concrete. First time I used one it made the job so much faster and easier. https://www.amazon.com/dp/B00UBQO3WO/?tag=atomicindus08-20
Second tool I thought of when I was at Menards tonight. I worked for an electrician when I was in High School and for a year after high school about 25 years ago. We fished wires using fish tape and fish sticks. I got pretty good using them to add outlets and other stuff. But there are times where you just can't fish wires without cutting extra holes or where fish sticks won't work. Since then they have come out with long flexible drill bits that help when running a wire from a switch to some lights in the attic. Can stick the bit in the hole for the switch and drill up through the top plate and then fish a wire and add lights without any drywall repairs. But something I found a few years ago is the ball chain and magnet. It works great for a lot of hard fishing jobs. I used mine the other day to add a water line for an ice maker. Drilled a hole through the floor by the wall to bring an ice maker line up from the basement. The issue was there was a floor joist very close to the top plate, so no way to get a hand in the 1" gap or fish a line down. I was able to drop the ball chain down the hole and then use the flexible magnet to get in there and retrieve the ball chain and then tape the 1/4" flexible water line to the ball chain and pull it up. Not sure if I would have been able to do this without these tools. There's a couple videos on the amazon link that probably explain it better then I do. And if you have a menards these are only like 14 bucks for the kit.
What other tools are out there that other's may not know about?
banditbigdog
Southeast
Dowidat 20-23mm open end wrench with a brass “hammer” attached.
Not my photo, I have one in my toolbox however.
Purchased at an army surplus store back in the late 80’s.
They had several.
All 20-23mm
Recall reading this wrench was some sort of military procurement.
WWheeler
Middleofnowhere USA
Menda Wire Threader.
To help feed a wire alongside all the other wires in a harness through a grommet, wire loom clip, zip tie, etc. Or what I've also used it for is to open up a wire harness by slipping this under the harness tape and cutting against the 'V' in this tool to help reduce the threat of cutting any wires. It works really well to do that with a really sharp blade, like and exacto knife, to just slide both along to open it up.
richfinn
Leeds, Yorkshire, England
Love mine use it all the time 👍
olsenmotorsports
Chicago, IL
Use this every week! Great little tool that is
olsenmotorsports
Chicago, IL
Im not sure I have much to share in cool stuff?
OTC 4799 - wish I knew about this one 20 years ago. Its designated purpose is to grab caliper pistons internally and remove from the caliper. Beats the ol’ block of wood and shot of air!
Had it for a few years now and it’s done dozens of sets. Great bit of kit.
signcrafter
Mini flex 3/8
I have the non flex version, could see the flex coming in handy.
I bought one of these a few years back, think from a post on here. To be honest I forgot about it and haven't used it much at all. I used it for cutting open wire harnesses a few times to protect the wires. But think that's all I used it for.
Never seen those before. But also don't rebuild calipers because new ones are fairly cheap usually.
signcrafter
I remember the day many years ago when I found out strain relief pliers existed! I had mutilated several beyond reuse up to that point.
The ones I have are made by Heyco, but not the same company that makes mechanic tools in Germany.
https://www.heyco.com/products/stra...assembly-pliers-instructions-and-spare-parts/
Never knew those existed. Another one I didn't know about even though I've installed hundreds of chandelers is the chain ring pliers. Pretty sure I learned about it on here and added one to my amazon wish list but never ordered it. Guess what I need to hang later today? LOL
I've used hinge doctors to tweak commercial doors. Expensive but work awesome.
That's pretty neat, just uses the door opening to adjust the hinge right? I have the fastcap knuckle bender which is a crescent wrench looking tool with special ends for doing residential door hinges.
^ Wasn't that gizmo originally invented by a New Zealander?
Elastrator / Elastrator Co. Ltd., Blenheim, New Zealand / "Elastrator" castration tool / US patent 2447474 Aug 17 1948 Arthur Oswald Hammond / New Zealand patent Ser. No. 569406 /
So thoughtful of them to include the washable apron with every tool! (y)
Beerhippie
Far NE Oregon
I see a lot of Burdizzos at barn sales--the less "woke" way of doing it.
Ouch.
