rentonhighlands
- Joined
- Feb 2, 2016
- Messages
- 38
Hello:
I am building a 8x12 shed 16 oc with a 5' metal roll up door. I have some questions on how to build the roof rafters or trusses.
The shed will not be insulated
Walls will be 8' using 1 bottom plate and 2 top plates
When I build the walls should I use 2 studs on each corner of each wall stacked together?
Roof pitch is 5/12 2' overhang
I have figured out I need 6 trusses or rafters is this correct?
I would like to be able to put a or 2 4x8 sheet of plywood width for a upper space adding more storage.
My questions are:
Would I want to build rafters with a center beam running the length or trusses? What angle do I need to cut the rafters or trusses at?
I have a speed square what I am asking is how or is there a website I can input my shed detentions and the pitch and it will tell me the length of each board and the angles I need to cut?
My questions are:
