Shed Floor Sealant
Snapped-off
Indiana
Any suggestions on what to put down on a shed floor?
Flooring will be ¾" PT plywood. I'm planning to put down either some dime-pattern rubber tiles, or just lay a roll of it down.
Should I paint it? Seal it? Leave it bare and drop the rubber stuff down?
Shed will store all lawn and garden stuff. Tractors/tools etc.
PCustoms
VT
My shed floor is also 3/4 PT ply.
I had a can of porch and floor paint leftover from something else, so it got 2 coats. A little dirty but holding up fine to mower and generator wheels 2 or 3 years later.
mikedodge
I used grey floor or porch paint. I forget which now.
Don't put the rubber floor down unless you're in a desert area it'll hold moisture.
PCustoms
VT
Think it'll be bad even with a vapor barrier under the floor?
Yes.
Drips and condensation is going to build up under the rubber, unless you do something vented.
What's the desire for the rubber floor?
mikedodge
Yes. I think its the size of them that makes them more susceptible to temperature changes and lack of air movemtent but anything on the floor in a shed that can trap moisture like a bucket or mat or tire always ends up with condensation under it.
PCustoms
VT
I just kind of like it. Maybe I'll just stick with floor paint.
In this case, KISS.
If something ever happens with the wood/paint it should be easily noticeable. With my luck I'd put a foot or the mower through my nice rubber floor.
Codyboy
S.E. TEXAS
I just left mine bare wood.
It's just a small 16x20 where I have my woodworking tools . No lawn equipment or anything like that.
I was going to paint it with gray floor/porch paint but then thought about it getting scratched up dragging stuff around and then have to paint it again and again...
Been going good for 5 years . Other than looks, paint is not going to protect the floor from parking lawn equipment in it.
Snapped-off
Indiana
I may just throw some water seal on it and call it good. It'll just be strictly storage.
mikedodge
I always paint mine to protect it a bit better from any water and oil from normal use.
Snapped-off
Indiana
I decided to just use Thompson's transparent water seal. Shed is a 14x24, and I used 1 full gallon.
Maybe I'll recoat it every other year. Although I'm not planning on getting the floor wet.
