Shed gas line
fishspike57
Hudson WI
I trenched 1 inch pex to my pole shed for gas. went under and brought it inside. My question is I have enough left to go up in the attic and to the heater for that connection. I know I need to use galvanized pipe at the heater. Can I continue the pex or do I need to go to copper as soon as I got inside. Hopefully this makes sense. Thanks
LS6 Tommy
Northern NJ
Re: Gas Pex
What exactly did you use Pex, Pex-Al-Pex or HDPE?
Also, you don't use galvanized or copper for natural gas.
Tommy
Fixed
Ontario, Canada
Re: Gas Pex
Tommy
You definitely don't use galv, but in some areas flexible copper is the norm for natural gas.
Sent from my SM-G935W8 using Tapatalk
LS6 Tommy
Northern NJ
Re: Gas Pex
Not around here, especially for pilot burner lines. They have to be aluminum.
Tommy
86turbodsl
Re: Gas Pex
Gas pex is yellow, and always transitions to metal before it exits the ground. There are special connections for this. You use whatever your local code official wants to see, sometimes its black iron, sometimes it's copper. check with them.
LS6 Tommy
Northern NJ
Re: Gas Pex
Again, I'd like to know if the OP has Pex-Al-Pex, HDPE/MDPE or Pex. AFAIK, Pex is not allowable for natural gas. The "yellow Pex" normally used for direct burial gas service is not Pex. It's HDPE/MDPE and is only used for direct burial. Pex-Al-Pex is used for above ground.
Tommy
MrSurly
East Texas
Gas Pex
In my area, you are not allowed to “come up inside” the building or wall. Underground gas supply MUST transition to metal before surfacing and MUST be out side the building. Penetration into the building must be above grade and accessible. The underground yellow hope is not allowed to be used above ground or in the building, either. The underground plastic pipe also must have a tracer wire run along with it. (Not mentioned in the post).
From the sound of it, O.P. Is making some significant no-nos with the ‘wing it’ approach.
Not that I haven’t had to learn the same way, before.
MrSurly
East Texas
Gas Pex
I mean seriously, you’re hitting about 0 for 10, here.
Pex for gas. NO
Pex underground. NO
No Tracer wire. NO
No metal risers. NO
Continuous underground and into structure. NO
Piped underground into structure. NO
Plans for galvanized. NO
Plan for copper. NO.
I’m no expert but I did want to do similar a while back. I had almost exactly your plan... then I asked around some, was directed to the code requirements and and a bunch of Googling (and talking to plumbers while getting bids) later, discovered that there was a lot more to it than I imagined.
The point is not ultimately about meeting code or deciding what codes apply.... it’s truly first about safety. Gas needs to be done right to be safe for you and yours.
The Cobbler
Re: Gas Pex
I agree mostly with the others here. except copper & gas can be used in some areas, depends on the sulpher content I believe.
but pex is not rated for gas.
I bet your transition needs to be pipe & outside
and so on...
F
fishspike57
Hudson WI
Re: Gas Pex
I'm not sure or home to check. Went to a local plumber told him what I needed and he gave it to me. Sorry
jeepxj
Re: Gas Pex
a plumber gave you pex to use for gas inside a house?
Showkey
"MEMBER EMERITUS"
Wausau WI
Re: Gas Pex
Post #11 already said he is not sure so Not enough info so far .........but it might be a product like this:
The HOME-FLEX Underground 1 in. x 100 ft. Pipe is made specifically for medium to large jobs. Easy to work with and attach directly to our couplings or transition fittings for a simple application.
IPS size (Iron Pipe Size)
1/2 in. IPS size, 1/2 in. is DR 9.3; 3/4 in. and 1 in. are DR 11
Medium density polyethylene (MDPE) construction
Approved for direct burial in accordance with your local plumbing / building codes
Only for Underground use
For use with HOME-FLEX Underground fittings
Much lighter than and longer lasting than steel pipe
Durable polyethylene will last for years and years
MrSurly
East Texas
Re: Gas Pex
Not enough info but the title and statement certainly raise questions. I’m hoping that he actually used the correct pipe and laid a tracer wire. If so, he won’t need to start over, only do enough digging to install the transitions.
F
fishspike57
Hudson WI
Re: Gas Pex
Yep installed wire and will do the correct couplings in spring. Sorry if I didn't get all the info in first post. I meant iron and not galvanized. In Wi we can use copper.
MrSurly
East Texas
Gas Pex
I’m curious about the markings on the pipe you have, could you post a pic of it?
HoosierBuddy
Southern Indiana
Re: Gas Pex
This post brings up a lot of thoughts for me.
To the OP....I'm worried that you seem to have very little knowledge of how to do what you want to do here. You would be better off hiring someone that would make sure your job gets done right as:
1. If you do this wrong it could result in a leak that might lead to a fire or explosion.
2. If you do this wrong, even if you get it to work (sort of), it may lead to problems with resale of your property in the future when an inspector who does know how this is supposed to be done looks at it.
3. If you do this wrong and your gas provider becomes aware of it, they will be obliged to discontinue service to your property until it's all cut loose and made safe.
The "PEX" underground part is what is the most disturbing. PEX isn't allowed for gas, period end of story.
Phil
MrSurly
East Texas
Re: Gas Pex
The O.P. contacted me by PM (I'm not clear exactly why, but I'm glad he did!) Anyway, the pipe he trenched is correct and he did lay the tracer wire with it. It's HDPE
I linked him to the transitions and unions required.
I expect he'll get it sorted correctly, now.
MrSurly
East Texas
Gas Pex
Thanks not sure it went that way. Checking your message now
For some reason, my PMs that I’m trying to send are not sending... just gone.
So anyway, for your pipe you’re going to need two of these https://www.homedepot.com/p/HOME-F...EC-_-mobileweb_navplp_rr-_-NA-_-300867556-_-N
AND two of these:
https://www.homedepot.com/p/HOME-F...PIPHorizontal2_rr-_-300867556-_-300867551-_-N
I need to do exactly the same thing at my place.
RPH
Michigan Thumb
Re: Gas Pex
Here in the north Detriot the gas company uses galvanized pipe in there installations. So there is some made for this use.
D45
NW INDIANA
Re: Gas Pex
Yellow poly is so easy to work with
The push to lock connectors and metal transitions are good stuff
I used yellow poly for my patio grill a few years ago, ordered it all online
You will need a chamfer tool
MrSurly
East Texas
Re: Gas Pex
I know that Fishspike57 may have started this thread a bit awkwardly and his wording likely left the impression that he was not equipped for or serious about his project. For peace of mind, take a look at his "SHED"
I think he's being a bit modest.
k-os
WI
Re: Gas Pex
AND two of these:
Thanks for posting those links. I'll need to do the same for getting gas from my meter to my garage.
D45
NW INDIANA
Re: Gas Pex
https://hdpesupply.com/
I ordered everything from this business
Was only $178 shipped for a Constab coupling, 90 degree Constab coupling, 20 feet of yellow poly, a chamfer tool, a riser, and a straight transition
F
fishspike57
Hudson WI
Re: Gas Pex
Thanks. Trying to do things right but sometimes not using the right lingo causes a lt of confusion. Sorry and thanks I will have more question as I progress in the inside.
tricountytrail
Pendelton, NY
Re: Gas Pex
What is the standard method the professionals use when using poly under ground when they have to connect to the risers (which transition from under ground to above) do they use these connectors or use a fusion welder? To my understanding the riser in OUTSIDE the building then enters with steel pipe is this correct?
NUTTSGT
Northern Central Ohio
Re: Gas Pex
If you want to change the title of this thread to prevent future confusion, send me a PM, I can change it easily.
EDIT: Title changed as requested.
MrSurly
East Texas
I’m NOT a pro. From my discussion with pros and also code inspectors, the transition to metal must occur underground and the riser MUST come up OUTside the building. Gas line penetration into the building MUST be above ground and external to the building (can’t surface in a crawl space or basement.)
tricountytrail
Pendelton, NY
Thank you 14 gauge tracer wire and burial tape 12" above also in my area.
Jim greengo
Behind my house
Re: Gas Pex
They used to ***** about galvanizing flaking off inside of gas lines around here also,last I heard is the gas co now says that screens in gas valves will catch it so they arent worried .:dunno:
Jim greengo
Behind my house
There's still plenty of old gas services in Omaha area coming in through side walls into basement,with meter in basement.
They're gradually changing them out,but they will still be around for a while.
HoosierBuddy
Southern Indiana
Re: Gas Pex
The gold standard for connecting polyethylene is heat fusion. There are several methods which can be used:
**** fusion - ends of pipe are faced flat, melted with a heater and then brought together to "weld" pipe ends together.
Socket Fusion - A PE coupling is used. The end of the pipe and the coupling are heating to molten with a heater, pressed together and allowed to cool. Repeat for other side of coupling.
Electrofusion - The pipe ends are prepared by scraping or peeling, a coupling with a built in heater coil is placed between the two pipe ends, plugged into a special box, and that box ramps DC current into the fitting to cause it to melt itself and the pipe ends and then it is allowed to cool.
IMHO fusion is superior to any sort of stab fitting, especially if that stab fitting has o-rings in it, as they may fail sometime in the future.
When gas companies lay mains and install services, typically they are going to fuse almost all connections using one of the 3 methods above.
Normally risers are installed outside the building. Old systems often had gas meters inside...but that's becoming pretty rare these days.
I should note that the commercially available anodeless service risers consist of a short piece of PE that is fused to your underground line, enters a sweeping shield and is connected to a vertical piece of threaded steel via a compression joint inside the shield after it comes above ground. This is so if the shield leaks water eventually...it cannot rust out the steel section of carrier pipe, as that pipe does not extend underground.
This is considered to be "better" than the older method of transitioning to steel underground and then bending that steel upwards and threading the end to accomplish the same thing as the service riser accomplishes....BUT can leave a piece of steel underground to rust unless it is protected by an anode.
Phil
tricountytrail
Pendelton, NY
Re: Gas Pex
Phil
Thanks Phil!
D45
NW INDIANA
The Constab fittings with the chamfer tool is cake to use
Literally a push to lock style fitting
Skiff Builder
Southern NJ Coast
Re: Gas Pex
Tommy
Tommy,
After Storm Sandy,down the shore, all our towns nat gas meters were re piped with galvanized. All piping from meter to furnace/boilers on new builds also.
Don't know if the galvanizing process is different ???
