Sheetrock & Garage Door
MeBunkerYou
MN
Hiring a rock hanger to do the ceiling in my garage. When he came to take measurements he said he'd just drop all the door rail supports and opener down, hang the 5/8" and bolt everything back up. All garage door components were just professionally installed a couple months ago. Will I need to make any adjustments after everything being lowered 5/8"?
Thanks
deter
Indiana
most likely no. as long as he rehangs them where they were should be just fine
MeBunkerYou
MN
Thanks. Figured as much and I suppose I'll know when I open and close for the first time.
The Cobbler
when I did my ceiling, I took several measurements of locations of screws etc, shortened everything by the thickness of the ceiling (5/8" T&G pine) so it hangs in the same place .
nadogail
Coronado, CA
If the Rock Hanger operates the door both before and after he does his work, their should be no question as to the validity of his claims.
56Mark
Fall Branch, TN
Drop a plumb bob from the end of each rail and make a mark on the floor so you can put 'em back in the place.
toolmiser
La Crosse, WI
Take a bunch of pictures with a tape measurement in them. Will be real easy to place them back where there were.
MeBunkerYou
MN
Thanks for the replies. I will take some pics myself before and make sure he operates it first.
