Shingle question. Blunder correction.
go4donuts
Regina, Saskatchewan
So, I finally completed doing interior finishing on my garage (drywall, paint, shelves). Part B of the garage workshop plan was to build a 8x10 shed to get the 'yard and garden' stuff out of the garage.
I am nearing completion on the shed and have been pushing to get it done before snow flies. I got the roof sheeted this afternoon and started shingling at sunset. I finished about 1/2 of one side of the roof before I couldn't see to work anymore.
Later, as I was sitting in the house, it dawned on me that I goofed up the shingles - I forgot to put a starter strip up the rake of the roof. I DID remember to put a starter strip along the eave though. I've got about five or six courses started from the front edge - about 2/3 the way to the peak. The length of the roof rake is about 6 feet - it's a simple gable style roof.
I'm using laminated asphalt (aka 'random tab') shingles and I'm overhanging them about 3/8 of an inch over the metal drip edge strip. There is roofing felt under the shingles, if that makes a difference.
:headscrat Question: is this worth tearing apart to fix, considering it's a backyard shed? I think maybe I should just finish this one rake edge with no starter strips and put strips on all three other rakes. Or should I do the other rake edge on this gable without a strip so it matches? This gable is the front of the shed which faces the yard.
koditten
Midland, Michigan
I wouldn't worry about it a bit. As long as you have good drip edge, you will be fine. Does your area have a code in place stating you must have the strip?
KenC
oklahoma
I don't think starter strips go up the eaves, but I'm not a roofer.
I'm not either, but have installed alot of shingles.
I don't think the starters are required on the rake either. But, do use them just because it makes alignment of each row easier.
Dataguy
Northern MI
Helped my BIL roof his house a couple of years ago. We had a roofer in charge and the rest of us were cheap labor. :)
Starter strip only along the eaves, none anywhere else. I've helped on a couple of other roofing jobs over the years, never seen a starter strip used on the rakes. I would continue on as you have been doing and fo the other side the same way.
alwaysFlOoReD
Airdrie, Alberta, Canada
I'm not a roofer but have installed a lot. AFAIK the rake starter is for looks; when cutting off the excess there is a straight line to see when looking up. You're fine as is.
Richard
terry603
starter strips up the rake are optional, OK if not done
I like them only to have a nice straight edge
