Shoehorned mini split.
bluedog225
Texas
Nicely done. I probably want to tie that swing arm mount to the wall with something that could exert some tension. That will keep it from wanting to walk out with minor vibration overtime and put strain on your copper and wires.
Spikes
Arkansas
That was a concern during the planning phase, but it's rock solid with the pressure lines, drain and wiring going straight into the wall on the viewer's right side of the unit. There's no vibration or movement.
dscheidt
Is it secure against someone grabbing it and moving it? a couple pieces of chain might save a bunch of trouble.
aggie113
San Antonio, TX
That wall mount is making my brain twitch... Hopefully it stays good over time. Another way to do a corner mount like that would be to do a triangle into the corner bringing out a flat surface for you to mount something to.
