67-ls1
Hi,
I'm new to the forum and was hoping you guys could help me out.
I just bought an 80 gallon, 2 stage, 175 psi upright air compressor and want to plumb my shop. I have decided to use copper pipe.
My questions are:
- Where I rise up and then loop back down from the main run at each drop, can I reduce from 3/4" copper pipe to 1/2" copper pipe? The total length of 1/2" pipe in each drop leg would be approx. 5'. The drop would be straight with only a tee where a tool could connect above the water trap section. I plan on regulating the 175 psi near the compressor outlet to approx 100 psi (adjustable).
- What do you guys use for drain valves at the bottom of each drop leg?
- Where I have connections for tools, should I use cast bronze fittings with mounting ears or just use a copper tee and strap it to the wall?
- What do you recommend for quick couplers for the tools? I have had ones in the past that leaked pretty bad if the hose so much as drooped under its own weight. There has to be a brand/model that won't do this.
Thanks in advance for your help and suggestions. I only want to have to do this once.
Dennis
My questions are:
Dennis
