shop heater recommendation - propane
^&right
Indiana
24x32 shop. 8' walls. Very well insulated. Propane line already set up in a corner. I'd like to set it up with a thermostat for when I'm in there. Currently no vents are run, 120V present. Replacing an old unit.
Firebrick43
West central Indiana
If you very well insulated I would recommend some kind of vented heater. A ventless on will put lots of water vapor in the air.
Something like a modine hanging heater is going to be the cheapest/less space option, but no very efficient nor good circulation but that may be fine if its just for when you in the shop.
A radiant heater maybe more efficient/better heating of you due to being radiant but a little more money up front
Using an actual high efficient furnace will be, well, more efficient and better heat distribution(if piped correctly). The upfront cost will be made up for in fuel efficiency if you heat the garage all the time. More difficult install than the other options.
^&right
Indiana
Its one big open space. I had it in my mind to run a vented heater as that is what I am replacing. just a unit hanging from the cieling, but I'm open to other solutions. I could do a wall mount. I don't have the real estate to do a floor mount.
It will only be run when I am in the shop working, no desire to run duct work. Not overly concerned about water vapor. It'll only be running for hours at a time, not a full time furnace.
^&right
Indiana
^^This is the style I am replacing. It's an old unit I've repaired twice. Leaning towards retaining this style, but I know nothing about brands and who makes a quality unit.
dcg9381
Austin, TX
I have wall mount ventless.
The good news is they are cheap, simple, and produce heat.
The bad news is that in climates with moisture, you're keeping that moisture inside.
We don't have to "aux heat" (on propane) that much so they work fine here.
^&right
Indiana
I should mention I'm in NE Indiana. temps below 0* happen but aren't frequent. If it's that cold I'm not going into the shop unless I have to! ;D
dcg9381
Austin, TX
I caught that and factored it in.
If it's an "emergency heat" deal, I tend to go with simple and brutal. Vented propane is probably better moisture side, depends on how much hassle that is.
^&right
Indiana
Venting isn't a problem, but will have to go out the wall. Had a metal roof put on, not cutting a hole in it.
^&right
Indiana
Posted this same request on a car forum as well. The Modine Hawt Dog was recommended a few times there as well. Appreciate the posts Gentlemen!
