Shop panel upgrade
otef546
Please be gentle lol. Just a average diy guy.
when I bought the house the shop was already here. The electric service was poor at best. I made a decision to have a new meter set due to the distance to my house and the huge amount of rock I have. My electric companies transformer is literally 20 feet from the shop. I hung a new 200 amp meter/main disconnect box with feed through lugs. It has 4 spaces. Used them for air compressor and R/v outlet. Fed through to my new panel on opposite side of the wall. Reconnected my circuits with a ton of leftover space if/when I need it. Any constructive criticism is welcomed.
Looks like you terminated neutral and ground onto the same bar in the subpanel
This is a big no no
Ground wire needs to go to its own bar and the neutral bar(s) needs to be isolated by removing the green bonding screw.
Terry D
St. Louis, MO.
You need to install a ground bar to the metal can of the panel, remove the ground from the lug that it is connected to now and connected it to the new ground bar. All the branch circuit grounds need to be removed from the neutral buss and extended to the new ground bar.
Neutrals and grounds can not be tied together in a sub panel.
I only see one ground rod also. You should have a grounding electrode and a grounding electrode conductor in the meter/main
O
otef546
This is a big no no
I questioned this with my "help". I was told this wasn't technically a sub panel so separate wasn't required. I read it and understood it as you do but took the bad advice. I can correct it. What device to you prefer to extend my ground wires ?
O
otef546
Terry D
St. Louis, MO.
It is a sub panel. Your meter/ main is your main panel. It has your first means of disconnect. You did right by the 4-wire feed to your sub panel. There should be spots to attach ground bars in the panel. That is a Square D Homeline panel, just get ground bars made for that panel and the holes will line up to mount them. I like putting one on each side. If you have to extend the grounds on the branch circuits, i just use wire nuts and the same size wire. If you want to extend the main equipment ground to the ground bars, you just have to attach it to one, you can use a split bolt to do this. Make sure it is the same size wire also. You could also just add a lug down by the equipment ground and not extend it.
I still would think you need another ground rod. If your utility has a service hand book, it would be in there. what size is that conduit and wires feeding the sub panel?
Also, here is a thread on extending ground wires
O
otef546
Thank you. I will get it corrected. I do have two grounds, the second connection is under the dirt. Conduit is 1&1/2. Wish it was 2" but I already had it and was trying to save a couple $
O
otef546
The wire feeding the sub is 2/0 with a 4 gauge ground wire
yatg
Southern Oregon
Your RV circuit is using a red with white tape as neutral. Pretty sure that #6 and smaller neutrals must be white/gray and you're not allowed to reidentify them.
O
otef546
Ok Terry I think I have it corrected. Here's a couple pics
O
otef546
This is a big no no
I think I have it corrected. Pics are dark but I think u can zoom in and see
Terry D
St. Louis, MO.
Looks good. Is that splice connector you used dual rated for copper and aluminum. Most of them are. I know you used all copper, just making sure the connector is rated for copper. Other than that you have fixed the problem.
O
otef546
Yes it did say on the package that it was rated for both
Your “helper” was dangerously wrong.
Hopefully theyre not licensed.
See the electrical FAQs sticky for wiring diagrams.
O
otef546
Scary thing he is licensed. Thanks for your help. Bad thing I was 90 percent that it was wrong but let myself get convinced otherwise
