palumbogio
- Joined
- Mar 18, 2012
- Messages
- 12
Hi !
Help needed for shop remodeling I have a 24x24x8ft ceiling garage with a divider load bearing wall in the middle I would like to remove a 12ft section of the wall will a 2pc 2x12 header be sufficient for that span of opening? The trusses they run perpendicular to the wall in question above this wall is a 8’x24’small attic space
What I would like to do is
A 8 ft of wall on one side a 12 ft of header and a 4 ft wall at the other end my plan is to use 2pc of 2”x12” with a ½” filled plywood glued and screwed in the middle and have 3 to 4 jack stud at each end of the header is this sufficient for this situation
Thanks for your help
