Honestly, that's a "cheap" tool set. It will work for a lot of stuff, but when I need something to work I can't afford a failure just to save a few dollars. The tools will pay for themselves so why cheap out just to have it all right now. Instant gratification it sounds like here.
Do you have any suggestions? Alternatives?
I've got a pretty solid impact socket set in common sizes, so the chrome sockets are mostly for completeness and backups. That being said, I know professionals who use them with little complaint, but I can see why you would call them "cheap."
The wrenches are the best I could find at that price point; if you can find me a comparable set for even twice the price, I will consider it, but GW is supposed to be solid stuff.
Irwin makes the best pliers that I have ever used, and that's comparing them to some high end stuff I've used on different jobs. I would love to hear someone else chime in about them, but I have no qualms at all about using them.
I would like a better screwdriver set, but Sunex doesn't exactly have a bad reputation, and the only complaints are about the finish on the handles. Again, find me a better set that doesn't skip philips sizes and has bolsters on the shanks, and I will gladly pay twice as much.
Bondhus is cheap? Everything that I have read says that they are as good as you can get.
I can see why you might call ATD tools cheap, but they aren't **** (I have had several ATD tools over the years), and it's a hook and scraper kit, not a socket wrench.
Titan hammers come well regarded, Astro seems to get good reviews, and another Tekton set for pry bars. If you have some specific criticisms, please let me know, or better yet, present an alternative.
The Innova DMM is the highest rated unit on the 'net; there are some criticisms on the forum, so I will be looking at Greenlee, but only because Wavetek doesn't exist, anymore. The soldering iron... who cares?
Tekton Impact Driver. Is it cheap? Yes. Does it do the job? Apparently.
Brake and oil filter tools; I have the oil filter pliers, already, and they work great. Lisle is supposed to be good, and the caliper wind-back tool doesn't need to be heavy duty.
There is a reason for everything that I am doing, and if I have not explained well enough, I apologize, but your remark mostly comes off sounding like a tool snob; as if I am not worthy to do professional work if I don't have a $500 set of wrenches and $1000 worth of sockets.
Well, 25 years of semi-pro and heavy DIY work tell me otherwise. I have pulled engines, changed axles, and done more brake and suspension work on cars and trucks than I can even add up, using Kobalt sockets (Thorsen, at one point!), Craftsman raised panel wrenches, Stanley pliers (I have one pair of Irwins, and half a dozen random Craftsman and other garbage brands) and hammers, Ace brand tape measure and folding hex key set, and $1 screwdrivers from the parts store.
Everything on this list is either an upgrade from what I have now, or something that I have been going without, i.e. using screwdrivers instead of pry bars. The idea being that it will either be good enough, or it will fail and I will replace it with something better.
Again, if you have any specific recommendations, other than "Just buy everything off of a tool truck," please speak up.
