nvbigblue
Greetings!
My building is on it's way and will be going up sometime early next year when I get home. Since I've got plenty of time on my hands here, I've been drawing things up in Sketchup trying to get everything figured out.
My building is an S model arch building and the walls are straight up for about 9 feet. My plan is to line the metal with internal walls using 2X4 framing and 1/2" plywood. The shop is going to be sprayed with foam for insulation, so this will accomplish a couple of things:
1. Keep me from dinging the foam down low.
2. Allow me to mount peg board, etc. on the walls.
3. Prevent sparks from welding or cutting from contacting the foam.
So my question is this:
Should I run my utilities inside the 'sub-wall', like a normal house? Or should I conduit everything externally?
There should only be air, power and networking cables, but I have thought about a dust collection / general vacuum system as well.
The framing will be bolted to the metal prior to spraying foam, and then sheeted with the plywood. There will be some room on top of the walls, but with 3 separate runs, it might get tight with the foam. Or I run them along the length at some height off the floor. The only real benefit I see with using conduit is the ability to add another outlet or air drop a little easier if I needed to at some point. But if I ran things internally, I would save the cost of conduit and the walls would be a little 'cleaner' overall. I have not decided on pipe or something like the rapidair system, but I will NOT be using PVC for the air system.
So.... what are your guys thoughts on this?
NV
NV
