Above 1200 Sq/FT Shorty's Shed
cbacres
SW Florida
Last year coming back from KY we stopped in Bowling Green for dinner, just down the hiway from the Corvette plant. We passed carrier after carrier of brand ones on I-65, all covered in the shrink wrap. It was like a vette show in the parking lot of the restuarents, I think we had the only pickup there.
Bob Heine
Boca Raton, Florida
The Lance jar is full of matches my dad collected in the early 70's. Mine are in a box up in the loft. It will be interesting to look through these on day.
Shorty,
It was great meeting you Saturday. I hope we get to do it again.
I tried collecting matchbooks when I was a kid but my father was rightfully afraid I would burn the house down. We traveled across North America for a number of summers so I collected sugar packets. They used to be customized for restaurants and stores. Turns out ants liked my collection as much as I did so that one ended up in the same place as the matchbooks.
BBChevro
Brisbane, Qld., Australia
Hey Shorty, I just discovered that if I hover the mouse pointer thingy (please excuse the technical computer jargon) over the little star to the left of each thread in my subscribed threads list - it tells me when I last commented...
Which brings me to (shamefully) admit that I haven't commented here since March. :eek:
So I must tell you that I have been dutifully following along and have probably been nodding my head in agreement, or thinking to myself "wow, that's great" (many times over) - I just haven't printed it here.
So Shorty, I love the thread and (now that I've found the error of my ways) I'll try to comment on a more regular basis.
Keep up the good work. :thumbup:
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
Thanks Mark, you learn some thing every day.:thumbup:
Shorty how is the clear out going?
S
shortykorte
Tallahassee, Fl
Thanks for checking in. You haven't missed much plus there are so many great garages to follow, most nicer than mine. Hopefully I can get back in gear.
Oh, I'll need to try out your mouse tip. Edit: just tried the star thing. That will be useful. Thanks for sharing.
S
shortykorte
Tallahassee, Fl
1/2 Cup. Making slow progress but progress. I've been doing more staying up but it's needed. Hopefully tomorrow I get new anchors down and my Max Jax in operation.
Thanks for stopping by.
S
shortykorte
Tallahassee, Fl
Here is a shot of the garage since selling off a few things I didn't need.
After a mostly unsuccessful trip to the local forklift shop, the order picker is back home. They were able to get it to drive but not steer or lift. The order picker is 2004 model, has a couple computer board to manage all the safety interactions and the company has been brought out, so this makes things a lot more difficult for the regular forklift shop. Looks like a trip to Valdosta or Jacksonville is in order.:( $$$
S
shortykorte
Tallahassee, Fl
Used a 25% off coupon to buy the HF tire changer since one of my trailer tires is flat. I was going to weld a plate to the tire changer that match the MaxJax lift pattern. Before doing so I checked how far off the tire changer was.
Wow, finally I get lucky. Two of the changers bolt holes lined up really close but the holes were to small to use the MaxJax bolts. Well, off to the drill press. Using a step bit, bigger holes are drilled and the changer bolted in place. My George I think it will work. I try it out after my next project is completed.
S
shortykorte
Tallahassee, Fl
…and the next project is relocating the MaxJax. Looking at the original layout, I see the far post was off my almost 2 inches. :headscrat With this bad offset, the anchor pull out and moving lift to a better location I hope the move will be a win-win for me.
After measuring, remeasuring and doing check measures, its time to locate the new anchor locations. Reading in one thread about using spray paint to show the hole layout, I did the same. Works like a charm. I also found a 3/4" dia. washer with a small center hole to help locate the center.
Even using a center punch and small bit, some of the pilot holes drifted. :mad: Hopefully I'll finish the drilling tomorrow night.
S
shortykorte
Tallahassee, Fl
MaxJax question. What thickness concrete is this monted on. is 4" enough or should I plan for a 5" pad.
The first spot I put the anchors was right at 4". I'm hoping this current spot will be thicker. If I was pouring a new slab and knew the location of the MJ, I would definitely have 6" to 12" thickness in each area where the two post will go. Another thing to consider is the type of anchor. The supplied wedge anchors work with 4" but I think their expoxy anchors require 5".
Hope this helps.
polexican23
burbs-Illinois
worked enough for me. once I get a finalized-ish drawing I might have a better idea of where I will place the max jax. I was thinking of just doing the entire slap 5" to be safe. only a handful of guys on here can afford 12" pad all the way, I am not one of them.
S
shortykorte
Tallahassee, Fl
Sorry for the confusion. The entire slab is 4" with two 24" square holes 6-12" deep where lift goes.
NedNorton
Colorado, USA
Shortyykorte,
Merry Christmas and a happy new year! Just like sunbimmer, I appreciate you taking us along this year.
Cheers,
Chris
S
shortykorte
Tallahassee, Fl
Shortyykorte,
Cheers,
Chris
Merry Christmas from Buick Gardens Shorty. Hope '16 is the best ever
shortykorte,
Thanks for your comments and support in the past year, and thanks for sharing your endeavours with us :thumbup:
All the best for the new year !!
Thanks and I hope I can provide some comic relief with some of my endeavors.
S
shortykorte
Tallahassee, Fl
Well back to the MaxJax comedy hour. I installed the driver side anchors for the second location (attempt). Though the concrete was close to the limit, I think I have a good install since I used epoxy also.
Now, on to the passenger side. Did I mention, I don't learn from my mistakes?:headscrat
Instead of drilling a test hole to verify thickness, I employed the Tim "The Tooltime" Taylor method. Urgh, Urgh, Urgh. More power!!!! Drilled all five holes only to find a about 3" of concrete. :mad: Well this explains why I have cracks throughout the floor. When the plumbing was relocated, I bet the plumber wish there was 3" instead of 6-8".
Looks like this project is delayed yet again. Time to cut a hole, set some rebar and pour some concrete. :(
S
shortykorte
Tallahassee, Fl
Since the lift install is on hold, I decided to do a little organizing in the Lista Cabinet. This started of well until I tried to use some of the dividers from a Stanley Vidmar cabinet I was going to sell. The divider spacing is off by 1/16". Lista spacing is 3/4", Stanley is 13/16 and the Equipo cabinet is 7/8. I guess I'm keeping the Stanley since it has a lot of dividers with it.
S
shortykorte
Tallahassee, Fl
Since I'm keeping the Stanley cabinet, time for casters. Everything on caster!!!
I have some angle left over from when I built a frame for the tall Lista (pix 1). Now that I look at this picture, I'm going to redo this so the frame fits the outside of the cabinet. (Another project :wtf:) The second picture is the start of the Stanley frame (that will be built correctly the first time). The 90 degree brackets are MDF that I use on wood projects. Lets just say the corners are a little burnt right now. :3gears:
Well off to pack up outside Christmas decorations and hopefully finish this caster frame.
1/2 Cup
Member Emeritus
I have some angle left over from when I built a frame for the tall Lista (pix 1). Now that I look at this picture, I'm going to redo this so the frame fits the outside of the cabinet. (Another project :wtf:) The second picture is the start of the Stanley frame (that will be built correctly the first time). The 90 degree brackets are MDF that I use on wood projects. Lets just said the corners are a little burnt right now. :3gears:
I like your style shorty, upwardly mobile:thumbup:
We did our decorations yesterday.
Regards
S
shortykorte
Tallahassee, Fl
Yay! The caster base for the Stanley was smooth sailing. :thumbup:
Of course you have to show some welding pixs. The base freshly painted and in place ready for service. While at the swap meeting I was able to get 12 matching casters (300# rating) for a good price. I will replace the HF casters on the Lista (on right) with these lower casters. The last set will go on the short Lista cabinet.
S
shortykorte
Tallahassee, Fl
Since I had a little time left over I decided to start filling the Stanley up with building construction supplies. First was plumbing, then electrical. Some of the electrical came from when I removed the loft. The other is new stuff I will use to finish running conduit for new outlets. One great thing about these cabinets is that it is easy to rearrange the drawers when needed or move drawers up and down the stack.
taumac
Brooksville, Fl
Looking good sir. One tip I'll give up. If welding casters on run some tape between where the ball bearing are. This keeps welding splatter from getting in where ball bearings are and causing them not to swivel.
cbacres
SW Florida
Can't beat the Listas.
I'll be building a similar frame for the two I picked up. I spotted some 2x6 castors on a CL yard sale ad. Picked up 4 6" 4 4" for $10.
Looks good Shorty.
S
shortykorte
Tallahassee, Fl
Looks good Shorty.
Thanks. I like good deals. :thumbup:
Those cabinets are looking good, not to mention familiar. :lol: Good job on the frame and castors.
Thanks. Now that I'm keeping the Stanley, I wish I would have got 3 Stanley instead of the Lista, Stanley, Equipo. Oh well, hindsight. :dunno:
S
shortykorte
Tallahassee, Fl
This pass weekend I was able to work on the tool cabinet caster bases. Since the next base was for the short Lista, I used the top as the form. To ensure there was wiggle room, I put shims on two sides. The base painted up and ready for service. Welding = practice practice practice.
Thanks Gerard, I did the tape on the casters tip during welding and paint
S
shortykorte
Tallahassee, Fl
Since that base went together rather quickly, I decided to exchange the casters on the original base to the tall Lista. As you can see they are taller then the others (see post 188).
Out comes the 4" grinder and cut-off tool. Lucky for me I was a bad welder when I put these casters on. The welds were more glue then welds.
The new matching set went on, base painted black to match other two bases (I guess it's a GJ thing) and tested.
S
shortykorte
Tallahassee, Fl
:wtf: WTF? Measuring the heights of the tall Lista and the Stanley, they turn out to be about 3/8' difference in height. The "feet" on the Lista is a little taller.
Oh welcome to Garage Journal where you will be shown wonderful tools and things you can't live with (the tool cabinets in this case). Oh, they don't match? Well they have to match or you will get your GJ man card suspended. ****, can't have that!
I decided to section the Lista feet since they unbolted from the cabinet. While finishing the pieces so I could **** weld them the very dim light bulb went off. Why don't you take some scrap plate and use them has spacers on the Stanley. :sad:
To late!!! And this was good practice project for me. Besides Jack O, who else can say they have a "sectioned" tool cabinet. :D I'll have to get a picture of all three cabinets together.
cbacres
SW Florida
That's a good idea Shorty, sizing on top. I may employ that when I build mine someday.
cbacres
SW Florida
Must be referring to Taumac:lol_hitti
