Should all garage outlets be GFCI?
vern1
I am undertaking some wiring on my new garage. Have added lights and 110v outlets (3) and am just reading up on installing a 240v plug for a heater. Am also thinking about building an extension cord so I can move the 5000w heater around the garage where I am working. Most of the time I will be working on the car and although I don't plan to be spraying a hose around, there is a floor drain and I will be using water occasionally in my detailing. Should all my outlets be GFCI just to be safe?
Thanks!
jkeyser14
(rural) Maryland
Yes, they should. The quality of GFCI outlets has improved tremendously the past few years as well, so you shouldn't have any false trips.
Norcal
120 volt receptacles are required to have GFCI protection in a garage, shop, shed, but 240 volt ones are not.
Ray-CA
San Diego CA
I believe that you can install a GFI in the first outlet on the circuit and that will protect all the other outlets, downstream on that circuit. If you put more than one GFI on the same circuit, they will "fight" each other and end up tripping off all the time.
Ray
V
vern1
Ok thanks. Couple of more: since I have 3 of the 110v plugs on one breaker can just one of the outlets be gfci as that trips them all? if the 240v outlet runs the heater and I believe the cord is 12/3, should the extension cord be 10/3? The extension cord would be 20' max
Thanks again
V
vern1
You guys are fast! So the gfci should be in the first outlet ie the one closest to the breaker? Even if the 240v doesn't require it by code wouldn't it be a good idea if the extension cord is on the ground and possibly near water?
V
vern1
All the 110 stuff is already in and I believe replacing just the one outlet with the gfci would be cheaper than the breaker, correct?
Charles (in GA)
50 mi south of Atlanta
You probably don't want to price a 240v GFCI breaker (and they don't make GFCI receptacles for 240v so the breaker is the only choice).
Charles
V
vern1
Charles thanks I didn't know they didn't sell gfci receptacles. So is it common practise not to have 240 gfci breakers due to cost?
pattenp
Virginia - USA
Since it's not a NEC requirement is the most common reason they are not used along with the cost. A double pole GFCI breaker can run from $70 to over $100 depending on the brand and size. I bought one for my portable heater circuit which was a 20A Cutler Hammer CH style and paid around $125.
KPSquared
Wetaskiwin, Alberta, Canada
I have no GFCI on my garage. Not required by code on a detached here. So, therefore, I put none. I've never been electrocuted but I have been pissed off by constantly tripped GFCI's.
Kinda like helmet and seatbelt laws I guess. . .
pattenp
Virginia - USA
Well that's kind of obvious since you're here to write your post. :shocking:
pattenp
Virginia - USA
Mabye I should rephrase. . .I've never been electrocuted badly. . .been hit a few times.
Electrocuted means dead.... there is no more or less about it. :lol: I think shocked is the word you're looking for.
We electrocute people here in Virginia for capital punishment.
V
vern1
Anyone have any advice on my 240v extension cord question? ie should I use 10/3 if the main cord for the heater is 12/3?
I dont believe that GFCI's are required for detached garages here but I guess its a judgement call on whether its worth $125 for the 240v and $35 for the 110v just to be better protected. Its not cheap but if I go with an extension cord on the 240v outlet sounds like its prob a good idea
Thanks for all the advice
Stuart in MN
Minneapolis
We don't know where 'here' is, so it's hard to advise on whether GFCIs are required.
As for the extension cord, using 10 gauge wire will cost more of course but it won't hurt anything. Whether you can use 12 gauge depends on the length of the cord - unless your garage is gigantic, it probably won't be long enough that you need to worry about voltage drop.
pattenp
Virginia - USA
I use a #12 20ft extension cord with my portable heater and my portable A/C which both have #12 cords that use the 240V 20A circuit. The x-cord does fine, doesn't get hot and the heater pulls 16A. But, I wouldn't use a cord over 25 feet.
ovilla
Plainfield, IL
A 220V 60AMP GFCI is not that expensive. I put one in for my hot tub and it was about $60 at Menards. Anyway, go on your city inspectors website and check out what code is for your city and then follow their directions. If they don't have info on their site, then just call them from a work phone (if you don't want them knowing who you are) and ask them what is code.
Why are you using 12 or even 10 gauge on a 220 line? What amp circuit breaker are you needing for the heater? Is it a 30amp? I was just thinking that if you could go a little bigger on the 220 line then you'd be set for a future welder too.
pattenp
Virginia - USA
ovilla made a good point. I didn't think about it but if your heater is 5000 watts then that's almost 21 amps @ 240V, which means you need at least a 25A circuit. What kind of plug is on the heater cord?
Falcon67
Merkel, TX
All my 120V plug runs start with a GFCI. The old shop was the same way. In the last 14 years, I have not had a single false trip that I can remember. And those circuits have grinders, drill press, lathe, sanders, smaller air compressors, etc, etc used on them.
V
vern1
Here is Toronto. The breaker will be 30 amp and the heater plug is a 6-30R. The wire out of the heater is 12
ishiboo
Oshkosh, WI
Just a sidenote - just because an appliance uses a certain gauge wire does not mean you can use the same to supply it. :) (Not that you didn't know that, just saying.) Appliances often use a smaller gauge wire as the distance is VERY short and temperature and other conditions are all known and accounted for.
V
vern1
I am new to all this so dont know much!! But learning. I just figured that since the cord on the heater was 12 that a 10 or 12 would be ok for an extension cord (and i think most guys agreed with that didnt they). I am running 10 from the breaker out of the panel to the outlet
If i am running a 30A breaker on the 240 plug would that not be sufficient for a small welder?
Thanks
Zeke
Thanks
That's what I use. You will read here that you can up that breaker if the circuit is used for welding only. But I get by on 30A for stick welding up to 150A so far. The inverter TIG is no problem at all, but I haven't put the pedal to the wood on that yet.
pattenp
Virginia - USA
Thanks
Even though the heater has #12 cord the critical info you gave later was that the plug is a 6-30. That would dictate that the extension cord should be #10 and the supply circuit should be 30A for the heater.
V
vern1
Ok thanks. I am wiring up the circuit this weekend and it will be 30A with the 6-30 outlet. If i go with an extension cord i will use #10 wire
By the way i bought a small propane bullet heater (30-60k btu) and tested it out yesterday in the garage. It really heated the place up fast so i think it will work well to raise the heat level fast and then i will use the electric heater to maintain :thumbup:
V
vern1
Just be careful using the propane heater in an enclosed area. Leave some ventilation for fresh air.
Will do. Will leave the door or window open a bit till the heater is off. From what i saw yesterday I prob wont need it on for more than 30-45 mins but will provide some fresh air during that time. Since the heater is on the floor I will prob just open the garage bay door a couple of inches to feed it
Thanks again
pattenp
Virginia - USA
Thanks again
I figured you'd know to do that. You'd be surprised how many people don't read the instructions and die every year from carbon monoxide poisoning.
