Should I unbundle my electrical cords
mobiledynamics
Gotham City
I come for the LV world where neat and tiday.....is always a plus
I have a splice box with 10 pairs of 12AWG are bundled together, zip tied and then routed back out to a 1" pipe.
Inside the splice box, I have the entire bundle zip tied all nice and neat.....
In foresight, should I unbutton them and let all the wires be *loose* so that they can breath/dissipate heat ?
toplessHO
central florida
its fine ,I like neat.
unless its coiled around it will be OK
Im guessing you have nothing that will pick up any type of interference in there?
mobiledynamics
Gotham City
Not much load. I'd say 8-10amps max on 2 on the conductors, which would cover the fridge circuits, kitchen circuits, and the living room. Everything else probably sees next to nothing The kitchen circuit A or B MIGHT see a spike when the toaster oven or espresso maker is in use
The splice box is basically the middleman between my transfer switch panel and my main. Stock wire was a few feet too short, so I put a large splice box directly underneath the transfer panel. From there, it's roughly a 7 ft run direct back to the panel.
