Sixfeet4
Hello GJ,
After 3 years of planning, my shop construction is finally underway! Needing advice on finishing out the compressor room. I've researched as best I could (some of the old posts on here have photos no longer hosted), but haven't fully decided how to finish out the room or what material to use for running piping. There's been so many decisions made to get to this point, I just figured I would include the room and figure out the details when the time is right.
Love the idea of the RapidAir product (Particularly being able to run lines behind the Sheetrock), however, I'm afraid of leaks down the road. I see a lot of new industrial installations using some type of blue pex ran just like you would black pipe and it looks great, just don't know anything about it. pros/cons?
The room Dimension is 5'6"x6'x8'. I'm using 2x6 studs w/R-19 insulation, double Sheetrock on interior and a solid core 36" door. Exterior walls are brick. I live in South Texas and the shop will have HVAC, but this room will not. Going to install a 80GAL 5HP 2 Stage Champion or Quincy.
Looking for ideas on more soundproofing, exhaust for compressor, exhaust fan, tank drain, remote on/off switch, manifold layout, how to run air line out of the room into the shop, tubing selection, etc.....
Any photos you could share or lessons learned advice would be much appreciated.
Thanks,
Steve
Thanks,
Steve
