Show me your wrench drawer
mustangmatt70
Georgia
I've been unhappy with how my wrenches are organized. I have the plastic drop in organizer. I have regular box end wrenches, gear wrenches, offset gear wrenches, and stubby wrenches. I'd hate to dedicate another drawer to another plastic drop in. I'm hoping there is a better way.
sberry
Brethren, Michigan
I don't use that stuff, it's too tedious.
dale500
I'm A fan of using wire to make custom wrench holders. I use a mini ball bat with the end cut off to taper the loops.
Yarpo
Minnesota
I'm going to need to add a second wrench drawer for sure, the blackhawk wrenches are a little awkward to get out, thankfully they don't see much use and it hasn't been a problem, but I've also got a set of stubbies and that need added too.
Air21
I always wondered if it would be better not to sort them by set but instead by size, so like the 1/2" combo next to the 1/2" 4 way angle next to the 1/2" ratcheting...
Magnum440d100
Indiana
I’m interested in ideas too.
This is my SAE drawer. I use SAE more than metric....
I have my main wrenches upper/left. Then I have the others in their factory cases on the right. The space between the foam and front of the drawer is a catch all for the loose wrenches, as well as on top of the foam...
I think I need a bigger box....
chrisnazzy
Arizona
My wrench organizers in the righthand drawer are mostly Ernst.f4a55e8df6b66ebf49cc6426af26c9fa.jpg
Yarpo
Minnesota
Damn, how deep is that? Looks like you've got twice as much room as me lol
HotWire
Montana
Wrench Drawer(s) of my main box. Automotive and Bicycle specific reside elsewhere.
SAE Drawer
METRIC Drawer
There is some overlap that could be cleared up.
OTHER Drawer
This one needs some work.
packet
Here's one of my drawers:
Ernst rails work great. The straight rails are from Snap On.
jimmyin3D
southbay, CA
Went through a couple styles but it never ended up working right. The Snap On KRA15 was the best bet cause it’s customizable(cut and move where you actually need it)and like $10 free shipping from Snap On store.5eb726735874c1527a87313b4b34d945.jpgbdf042924dfa299fdf7cc1b6b97c5291.jpg4a6c1f5e3e3d0bdea78b80985ee1dcf6.jpg
thr3squared
CA
Nice setup! Do the wrenchs sit tight in those organizers, or more loosely?
jimmyin3D
southbay, CA
They sit tight probably the best for making sure there isn’t wasted space. They also offer another wrench rail KRA17 or something like that which is for bigger wrenches but I’ve never tried those.
zmotorsports
Northern Utah
I've had to play Tetris with wrenches for years until I finally landed on a configuration that I am happy with. I don't like the big trays that they come in as they waste so much space so I utilize the tighter configured racks for the most used wrenches and then used wire that I would around a mandrel on my lathe for the others.
I'll have to see if I can find a picture that's handy.
BarryWells
In the mountains
MICE. Similar to my metric drawer. I have the equivalent in SAE but they live on the shelf in their original rolls.
Rickster
SE PA
I use a combination of wrench racks, Ikea dish drying racks and CD racks. The metric drawer has a Harbor Freight multi organizer with the other racks sprinkled in. Works pretty good.
homebuilt burner
central Wisconsin
Just miscellaneous wrench holders. Simple but it works for me.
Ed_Hazard
Los Angeles
I finally settled on the Ernst rails, tried a bunch.
SAE wrenches.
Ed_Hazard
Los Angeles
Metric, have up to 24mm on here as well as some of the beefy SK ratcheting wrenches.
Ed_Hazard
Los Angeles
Mix of Ernst gripper and "tray" rails. They work real well on the older CM raised panel wrenches. The crows foot fit nicely on kobalt socket rails.
Ed_Hazard
Los Angeles
Work well on box wrenches as well.
Ed_Hazard
Los Angeles
And some of my over 1" combo wrenches. Good use for a deep drawer that was not deep enough for power tools.
ku17
Here’s my 4 drawers. I use Hall wrench racks for my two main drawers and the other two are a free for all. The Hall racks made a huge difference when I added them a few months ago. I was able to free an entire drawer in my box. Still plenty of room for improvement. The drawer for the jumbo wrenches definitely needs a better solution.
jrg
Seattle, WA
I’m currently using kitchen utensil magnet bar. Also experimenting with a bolt and wing nut to keep some of the lesser used wrenches together.
749c6c8342b1210999c731be2723c004.jpgbdd67b99e5633f98262c01f56d876a95.jpg3df99306fc08cfe3e915369876a26409.jpg
