Show Off Your Antique Ratchet
Here is another offering. It’s a Billmont rachet.
It's not a ratchet. It's a free spinning wrench. More like a universal joint inside a tube.
The larger Billmont set
They made an even larger one. You can see an example on the GJ Billmont thread along with other information. You can find it in the A-Z Index in the Sticky at the top of the forum, along with hundreds of other threads you may not know we have.
Patrick Eubanks
The larger
thanks so much for directing me. I’ll be reading all weekend now
Patrick Eubanks
It a good read. I had a chance to buy the larger set on eBay about a month ago and messed around and was sniped at the last minute. I still regret that
Patrick Eubanks
Oh guys I need some help. I bought this set because of the obvious cool factor in hopes of finding a makers mark or some sort. No so easy. I’m hoping you guys can possibly provide some insight
Here's some insight...., I WANT ONE! :)
No, seriously, I have never seen that before. Systems with male drive tangs are unusual to begin with. I have a few (early Herbrand, Eastern Machine Screw, CM&D, and SWF from Germany) that tickle my excess pride, but that is a really cool set. It's interesting that the mfgr machined the square tang down to round on the very end. Also, those 8-point openings almost look like Wright's famous 10-point openings, which they attempted to say would fit both hex and square fasteners. I think it's just the way the points are not symmetrical.
Patrick Eubanks
The sockets are very heavy like the forged ones produced by Billings and Spencer around 1920
Patrick Eubanks
A
AntiqueBen
I the handle is trimmed with brass
Quite interesting. Looks early. The 2 screws that allow the front plate to be removed exposing the guts reminds me of the early Lowell no. 1 ratchet design, but Lowell didn't use a wooden handle at any point. If the handle was steel, it would remind me of Lowell. Lots of ratchet designs had an exposed gear like some of the Packer ratchets & several others. Have you removed the screws yet to look at the inside? You might find some clues. Post a pic if you do.
Patrick Eubanks
Quite interesting. Looks early. The 2 screws that allow the front plate to be removed exposing the guts reminds me of the early Lowell no. 1 ratchet design, but Lowell didn't use a wooden handle at any point. If the handle was steel, it would remind me of Lowell. Lots of ratchet designs had an exposed gear like some of the Packer ratchets & several others. Have you removed the screws yet to look at the inside? You might find some clues. Post a pic of you do.
I’ll do that today
^ on that one I just linked to.... after finding another one very similar, but marked for its intended purpose, I am wondering if some of these are stove ratchets - hand-held devices used to open and close the dampers on stoves and furnaces.
100% conjecture and speculation, of course.
A
AntiqueBen
^ I will second all of Private Lugnutz's observations, and sit here puzzled as to why they would machine down the drive ends of those sockets. (Or were they forged that way?)
The brass ferrule makes it smell British.
Just my two cents.
as long as we're talking about weird old ratchets about which none of us have a clue... this beauty showed up on ebay a couple days ago.
I agree with fourcycle. Your ratchet set could be European. Like he said, maybe British or it could be German. Not sure about the socket design though. That will be a fun research project trying to figure out the mystery. The info has to be out there somewhere.
...puzzled as to why they would machine down the drive ends of those sockets. (Or were they forged that way?)
Either way, it's odd, because it seems unnecessary.
Couple other observations...
- No accessories. All my sets with male drive tangs have an extension and/or a knuckle joint, maybe an L handle.
- All my sets with male drive tangs that are forged and/or machined (Eastern Machine Screw, Spezial Werkzeuge Fabrik) are hex drive, except Herbrand, which is square, akin to early Plomb. All my other sets with square male drive tangs (CM&D, Syracuse, Charles Miller) are malleable iron.
- All the sockets in my male drive tang sets have 6-point openings. Double-square is bizarre. If it was automotive, that relegates it to plugs.
@Patrick Eubanks What is the drive size? Is it 1/2-inch? Or something odd?
Patrick Eubanks
They are all 1/2 drive. I looked at the box and initially thought it may be home made box for the set because it’s so clean but after closer inspection I think it’s original. Dove tail edges and heart lumber the the top and bottom plates. The bottom plate actually has some slight separation. I think it’s legit. I didn’t see any signs of provisions in the box for extensions.
Yacobotz
I didn't go through the entire thread so I don't know if anybody else contributed this particular ratchet. It's quite primitive.
**I uploaded like five images so I'm not sure why I'm only seeing one?
A
AntiqueBen
We're only seeing the 1 pic. Looks interesting. Please post the other pics.
I didn't go through the entire thread...
Search tool is located upper right. You can search on entire site, just this forum, or just this thread.
...so I don't know if anybody else contributed this particular ratchet. It's quite primitive.
That patent date showing is Bartholomay (876,680). Is it marked Will B. Lane? We have a Lane thread. Might be a few Lane rats on this thread as well. But you can see more, including entire sets, with sockets in a wooden box, and lots of info on the Lane thread. See the "READ B4 POSTING" Sticky at the top of the Forum for an A-Z Index of threads, under "W" for Will B. Lane.
esben57
Sheffield. England
Sticking this here. Found this Gedore No. 1693 oddity at a flea market yesterday.
The hex and anvil both measure at 13mm, ball to sit in a relief such as a socket. Nothing in the female, no push thru coupler with it.
Ratchet and breaker in one ? But 13mm drive?
Strong mechanism but crude, flip over reverse.
The only hex drive I have seen are Britool at 7/16"
Any ideas?
A
AntiqueBen
Any ideas?
Looks like Gedore is a German company that opened in 1919. According to their history page on their website, they made their first wrench in 1936. I believe there is a thread somewhere here on GJ talking about Gedore. Cool find. Very unique ratchet. Here is a link to Gedore's history. They may have made tools before 1936. Further down the history page they elude to this saying after opening in 1919 they were making "adjustable spanners & other tools."
^ I can't say that I'm at all surprised. 13mm is damn close to 1/2", but I would think it reasonable to assume an old German-made Gedore would have been made to metric specs.
Gedore / Gedore Werkzeugfabrik GmbH & Co. KG, Remscheider Str. 149, 42899 Remscheid, Germany / https://www.gedore.com/ http://alloy-artifacts.org/european-tool-makers.html#dowidat / http://progress-is-fine.blogspot.com/2018/03/german-austrian-wrench-makers.html / https://www.garagejournal.com/forum...d-australian-made-tools.503971/#post-10344676 /
esben57
Sheffield. England
GEbruder DOwidat REmscheid
Family fall out, good tools used them without any issues. This is an odd item, will be someone somewhere who will know about it.
I'm impressed. That's an elegant and efficient design using the ratchet as a hinge handle. Love that set. I have a couple antique drive sets that sort of flip the idea around, turning a hinge handle into a ratchet with a ratcheting attachment.
Farmer J.
UK, Cornwall/Hertfordshire.
I have some Gedore hex drive sockets but only a big 'L' hex key to drive them. Never measured the drive size, will have a look if I can dig them out tomorrow. Maybe this is the ratchet/hinge handle to go with them!
A
AntiqueBen
Here is an early evolution of the Lowell no. 1 ratchet. Of course these were not designed for use with sockets, but you could switch out the gear for a different size opening to accommodate different size fasteners. These are among some of my oldest ratchets. The flat handle no. 1 was patented in 1864 & matches the ratchet design on the original patent (1st gen). These are extremely hard to find. The only flat handle I've ever seen in the wild is the one I've got. The other round handle with the selector on the head is also patented 1864 & is probably the 2nd generation. The other round handle is patented 1886 (3d gen) & has the pawl selector at the bottom of the handle which is quite unique. If you guys are interested I could post some pics of the guts. The inside is probably more interesting than the outside. Pretty unique mechanisms.
There is some question about the manufacturer of this unmarked ratchet. Other than not having dual bands of knurling on the handle it resembles early S-K. There is a similar looking ratchet shown on Alloy Artifacts with Indestro markings. Any thoughts? Please ignore the early S-K sockets. IMG_0184.jpeg
A
AntiqueBen
I think Indestro was known for not marking a lot of their tools for outsourcing purposes. But there's definitely SK attributes to your ratchet too. Did SK always mark their tools? Seems like they always did, but I could be wrong.
isb cornbinder
There are more. I do not have pictures, yet. There is a trap.
A
AntiqueBen
There you go Don. Looks like SK according to Oldtuleguy's post above. His ratchet in his SK set looks like yours.
Hinsdale sold that ratchet as well. The only difference I can tell is knurling on handles seems to vary. Anyone ever see a patent on one?
Cruzan80
Denver, CO
Let me grab a pic next time I am outside. I have at least one Lowell with the selector in the bottom, and at least one "known" SK (came in a Fulton box set), and at least one "unsure. Maybe side by side, some comparative or different points will show up
Indestros are usually marked.
Indestro 657 non-reversible 1/2" square drive ratchet
curiously, a #657 is a "long extension" in the 1935 catalog (pp 17)
#657 does not appear in the 1937 or 1948 catalogs or price lists
:dunno:
