Show off your band saws
jabberwoki
puyallup wa usa
I`ve got 3 now the DoAll the Racine and a Rockwell super heavy duty i`ll have to get a photo of that one later.
Nutria
Eastern Sierra
Atlas 912, 1950 w/ Craftsman motor. A little 12" feller, but it punches a bit above its weight and it has a decent resaw capacity for a small bandsaw. Very smooth, little drift. Lots of cast iron (see catalog description below).
WisJim
Menomonie, WI
I have an older Delta Rockwell metal/wood cutting 14" band saw. It was given to me by a good friend over 36 years ago. He had moved from Chicago to western Wisconsin and had to clear out a storage garage in Chicago, and asked me if I wanted some tools. He showed up with a load--this band saw and the base (still in the original carton), and two wood shapers. Nothing was absolutely complete, small loose parts were missing, but they were all unused. I had to find some bits and pieces for the saw, such as motor mount, motor and pulley, switch, table insert, etc., but the saw had never been used. (It didn't come with the light.) Same with the shapers, which I sold to a wood worker friend some years later after deciding that I would never use them enough to warrant getting them running and finding space for them.
isb cornbinder
Your bandsaw it the very desirable two speed Rockwell. The fitting at the bottom front is for putting oil in the lower gearcase. There should be a lever on the right side, behind the pulleys, to move a shaft in and out to disconnect one set of gears.
crguy
SW Washington
That's actually the newer model that you push/pull that knob in the center of the top pulley to engage/disengage the gearbox. I've owned both models.
Jgaz
My single speed Delta/Rockwell. Built in 1957. Early 90’s barn find.
Probably my favorite tool.
Oregon rock crusher
West of Salem
I was going to put up a few pics of my motley crew of verticle band saws but realized I didn't have good pics of any of them. Anyway here are a few bad pics. The big ones are packed in a storage container so tight it's hard to tell what's there. Probably time to thin the herd a bit.
A craftsman with stand that works and a nearly new Jet are both in the wood shop. The little red Wood Wizard works and is kind of neat. I've got a little toy kind of snowflake saw hanging on the wall but I forgot what it is. Out in the container is a 36" L Power saw that I plan to get going...also a 26" Crescent or Silver saw....not sure which. There is also a 24" DoAll stuffed in there for now. It works but will probably ride out the winter in the container. I almost forgot about the Marston old foot powered saw. I won't even start on the horizontals. Ed.
MushCreek
Upstate South Carolina
First up is a 1958 14"IMGP5354.JPGIMGP5822.JPG Delta that I rebuilt and painted recently. Also, a pic of 'The Beast', an old Kalamzoo 824. That's right; it takes up to a 24" wide cut! Too big for my needs, but at $150, I couldn't resist, and I found a slot to roll it out of the way. All it needed was new guide bearings and a fresh blade. Some day maybe I'll do a cosmetic restoration on it.
tombell572
Sea Cliff, NY & Portland, OR
Here's another Racine. It's a 14" saw with a 2-speed gear box for wood and metal and would be the same as Jabberwoki's. It has what could be the original Westinghouse 1/2 HP motor. I've seen pictures of other Racine saws with identical cast iron stands and believe this one to be original.
Tom B.
11b30b4
GA
I have 3, all Craftsman. My 14” mid 2000 (no pics) is my primary wood band saw.
This is my 12” 2-wheel King Seeley (103.24260) 1963 band saw with pedestal stand. It has a 15:1 gearbox reducer and metal cutting blade and is my primary metal cutting band saw.
full
This is my 12” 3-wheel King Seeley (103.24300) 1950-1956 band saw with pedestal stand. It has a Craftsman Slow Speed Converter (9-2342) with a 10:1 reduction and a metal cutting blade and is used for metal cutting.
full
jd5000
Massachusetts
Hi Jeff, would the pedestal in the photo above on the right (3-wheel band saw) fit the band saw on the left (2-wheel)?
Jim C.
Here’s my 2001 Delta 14”, USA made, bandsaw. I bought this bandsaw new from Tool Crib of the North. When my grandmother died, she left each of her seven grandchildren a small amount of cash to “spend or save.” My inheritance came with these simple instructions, ”If you haven’t done so already, buy that bandsaw.” It’s definitely one of the more frequently used machines in my shop and certainly the most appreciated.
Jim C.
