Where's that Rockwell? The DoAll and Racine snowflake are outstanding. What is the Racine, 16"?I`ve got 3 now the DoAll the Racine and a Rockwell super heavy duty i`ll have to get a photo of that one later.
Ah, you have the stand. I've wondered about one of those for my old Porter-Cable Portaband; the stands don't seem to show up too often.The aforementioned Rockwell.
No, I mean the entire bracket and base that attach to a handheld Porta-Band.Just pipes that go into the base.
Your bandsaw it the very desirable two speed Rockwell. The fitting at the bottom front is for putting oil in the lower gearcase. There should be a lever on the right side, behind the pulleys, to move a shaft in and out to disconnect one set of gears.I have an older Delta Rockwell metal/wood cutting 14" band saw. It was given to me by a good friend over 36 years ago. He had moved from Chicago to western Wisconsin and had to clear out a storage garage in Chicago, and asked me if I wanted some tools. He showed up with a load--this band saw and the base (still in the original carton), and two wood shapers. Nothing was absolutely complete, small loose parts were missing, but they were all unused. I had to find some bits and pieces for the saw, such as motor mount, motor and pulley, switch, table insert, etc., but the saw had never been used. (It didn't come with the light.) Same with the shapers, which I sold to a wood worker friend some years later after deciding that I would never use them enough to warrant getting them running and finding space for them.
That's actually the newer model that you push/pull that knob in the center of the top pulley to engage/disengage the gearbox. I've owned both models.Your bandsaw it the very desirable two speed Rockwell. The fitting at the bottom front is for putting oil in the lower gearcase. There should be a lever on the right side, behind the pulleys, to move a shaft in and out to disconnect one set of gears.
Delta that I rebuilt and painted recently. Also, a pic of 'The Beast', an old Kalamzoo 824. That's right; it takes up to a 24" wide cut! Too big for my needs, but at $150, I couldn't resist, and I found a slot to roll it out of the way. All it needed was new guide bearings and a fresh blade. Some day maybe I'll do a cosmetic restoration on it.That retirement light is pretty bright, even when it's turned off.First up is a 1958 14"
