Show off your sheet metal fab projects
Boiler
Indiana
This is an aluminum off-road bumper I made with a guy I work with. I did the design, we both made parts, he welded it, and we both finished it. Finally it was powdercoated. Not the greatest paint surfaces...we're used to round tube that hides a lot more. Turned out pretty good I think. I've got about 5 people that are waiting for me to make them one after I finish tweaking the design.
blue dog
Culver City Ca.
I dig your bumpers Boiler. Most have no idea the time it takes to do this. Are these steel or aluminum ?
They are very clean. do you build winch bumpers for the front ?
Boiler
Indiana
I haven't done a front bumper yet.
The bumper mounts to the uni-frame where the tow package normally mounts, with 3 x 3 x 3/8 tk aluminum angle, with a partial added flange making it a c-channel. There are tubes connecting them (for hitch option only) that are 3x2x1/4 wall rectangular aluminum, and the reciever itself is 3" sq x 1/2" wall (try finding stock in that...). Finally 95% of the rest is 1/4" aluminum plate. Everything is 6061-T6.
The way I do these things (I do roof racks too) I have to determine the geometry of the jeep, convert that to cad, then design the item to fit it. Then I design a fixture to build it on. When I'm done, it fits great (hopefully) and its repeatable without building to fit every time.
We had about 20 hours in measuring what we were building around, I had about 120 hours in CAD for the design and fixture & drawings. Then we had the goofy parts waterjet cut and we made the rest. Total fabrication from drawings was probably 30 hours, including head scratching, corrections etc. Basically I worked on it for about 3 hours a night from Feb 1st thru june 1st. Been very tough to get motivated to make the corrections....
You can see that we had some warpage drawing the outside ends down if you look directly on the rear. It caused some weird fitting with the fender flares and such because we really had no way to correct it. My friend that welded it took it out of the fixture after tacking it to make the interior welding easier. I could have killed him. Next time every piece will remain bolted to the fixture until its 95% welded & cooled, and hopefully we reduce that warpage considerably. I'm also modifying the way the parts are made to alleviate some of that, and we're going to play with the weld order to help too.
NASTYZEN
St-Colomban,Que. Canada
Got a question for you fabrication guys, What does it take to get an apprenticeship in fabrication shop that does classic cars or anything close to it?
Or a restoration shop.There is fabrication shops all over south florida, but very few for classic cars.
:fingersx:
First thing is to get the basic skills like welding and mechanical and lots of determination.The way I got into racing was by hanging around the tracks and offering free help.Once people see you are dedicated and hard working,it makes it easyer to justify training someone.
blue dog
Culver City Ca.
Boiler, if you built bumpers for jeeps side from the Liberty, i bet you could make a living at it. Quality bumpers for the trail rig guys are not cheap.
ZTFab
Upland, CA
Here are some aluminum dash's that I've made for some Polaris RZR's and an R1 powered Yamaha Rhino.
All were hand formed 3003 .050" aluminum. Tig welded and blended.
Another one:
LIVELY
Illinois
GREAT WORKMANSHIP:beer:
is it powdercoated or painted when done?
panels still removable?
average time constructing the dashes?
nice:bounce::bounce:
ZTFab
Upland, CA
Thanks. :beer:
They are all powdercoated.
All panels are still removable with the DZUS fasteners.
anywhere from 20 to 60 hours.
LIVELY
Illinois
i really like fabs like you do
you got any other forming pics? -that you would share--if you don't i understand
did you weld completely or how did you get smooth joints?:headscrat
ZTFab
Upland, CA
I form the radius edges like this.
Make flat patterns of the part
I then "tip the edge" of the sheet metal with my bead roller equipped with a "tank roll" die
The I use a hammer and T-Dolly to finish the radius.
On most of these parts I will actually form the full radius on one side of the piece and leave the mating piece completely flat, others I will form half of the radius on each part and then join them.
It depends on how big of a radius you are trying to achieve.
Here is a pic of how it looks when I get the parts formed and tacked. From here I weld them completely, hand planish the welds with a body hammer, and then grind/sand away the excess, then finish with a DA sander.
I use the same technique when I build the LED enclosures:
ZTFab
Upland, CA
How about some pics of the whole machine at once?
No problem!
Here is the one with the black dash: 2009 Polaris RZR S
The one with the Gray dash: 2009 Polaris RZR S
The one with the Orange dash: Yamaha Rhino with R1 motor
ZTFab
Upland, CA
Both RZR's are the stock Polaris 760cc HO Twin cylinder engine with just an intake and exhaust.
They make 51~ horsepower and push these little cars to just under 65mph.
The Rhino on the other hand has a 1000cc Yamaha R1 street bike engine shoved in it with an RPM FNR diff unit and is chain driven utilizing the R1 6 speed trans.
The motor has been upgraded and tuned to 180HP and the car weighs 1500lbs.
It was clocked in Ocotillo Wells on GPS just shy of 100mph with another gear to grab.
ZTFab
Upland, CA
Here's some more work from the R1 Rhino.
I had to redo the rear shock mounts since the guy that built the chassis didn't know how to.
All pieces were either hand cut on my band saw or on my shear and dimpled using my JMR dimple dies. The shock tabs are 3/16" CRS and are TIG welded. The shock mounts and cross brace are all 11ga CRS are MIG welded.
The Shock mounts:
The Shock Tabs:
The Cross Brace:
afazz
Pittsburgh, PA
Holy **** those welds are perfect! I'm not on that level, but here's some work I'm doing to my VW.
I'm cleaning up the engine bay, it's a show car. Here are some pics of my reworking and shaving of the firewall.
before:
I had to turn a new set of dies for the bead roller to match the depth of the OEM flange.
Tonight I threw some primer on to see how it's shaping up.
The remaining holes aren't getting shaved, but the insert bolts will be plug welded and ground smooth.
e-tek
Saskatoon, SK
ZTfab - ARTIST IN THE HOUSE!!! Holy **** now THAT's Fab work...and welding!! thanks for showing off your work. Now I want a rad-ATV too!
MP&C
Leonardtown, MD
Disecting & fabricating on a rusty wagon tail gate. the outer skin looked fairly decent for 55 year old metal, a couple pin holes showing....
The major issue with these tail gates, due to how they lean forward, any water collecting inside lays in the inner panel....
.......as you can see from the rear....
We laid out the proposed cut lines, used holes in the inside corners to add a radius, and made some sparks...
The tailgate has some internal stiffeners to help support the loading and unloading, and they have suffered some damage as well....
Since they're just spot welded in, and it will be easier to weld in newly fabricated ones than attempt repairs of the rusty ones in place......
We'll need to unfold some flanges to remove the rest of the inner skin....
MP&C
Leonardtown, MD
Probably one of the biggest challenges in taking things apart for repairs is doing so without inflicting more damage. I had seen a recent post on pliers used to remove door skins, and thought they would come in handy here on the bottom of the tailgate.
This is why you never throw away Vice grips that have the worn off teeth that have just lost their bite. The lower jaw is modified to receive the edge of the door skin...
Then a suitable "blade" is found....
Some welding and grinding, and we have a new body tool.....
Starting at the corner, a diagonal slice is made in the inner panel so it will remove easier...
....and the tool is used to gently pry up on the flange of the tailgate skin.....
Spot welds were removed with a burr grinder, in an attempt to keep the damage (and hole diameter) to the skin flange at a minimum. Continuing:
Next we'll work on making replacements for these structural members:
MP&C
Leonardtown, MD
Fixing one of the rather "rotted" parts that came out of the tailgate. This actually serves as a bolting plate for the tailgate hinge, so it definitely is in line for replacement.
Started with a piece of 16 gauge CRS and using the Wheeling Machine, prestretched the area for the stiffening bead.
...and with bead...
The Neil Dunder tooling....
A bend relief cut in the bead, panel bent, and welded...
Missed a few in process pictures here, but using a piece of 3 x 3 square tubing as a die, a 2 x 2 as a punch, and a BABPH to apply pressure, a relief for the tailgate rib is formed.
Trimming to size....(note 3 x 3 die in lower right corner)
Needs holes drilled yet...
test fit....
Alignment of hinge hole....
MP&C
Leonardtown, MD
Using some MDF for hammerforming the inner tailgate, the MDF is stacked to allow the flange to be folded downward.
The first three layers are aligned and screwed down, then the 18 ga CRS and "locking" layer of MDF is screwed down, through the entire pile using 4" long screws. A slight flange is also folded at the bottom to help "lock" the bottom edge of the plate against the MDF and hopefully prevent any pulling. Don't think it is needed on the straight bends, but it may help toward the corners.
Flange width marked and trimmed. The corners are cleaned of any burrs that may promote cracks to form by using a 3/4" dia drum sander.
Straight bends are worked with a low crown hammer to start the profile........
........and as the corners tighten, this was the most effective stretching device. Repeated overlapping rows made short work of the stretching..
....and the door skin hammer was used around the perimeter to "sharpen" the bends...
With the first bend complete, the Lancaster shrinker is used along the folded flanges to match the crown of the tailgate skin.....
............here compared to the lower tailpan....
....to be continued
Orangestang
Glendale ,AZ
MP&C Is body work what you do for a living? It all looks great. Or are you doing this on your own? Theres not enough hours in the day to do all that with a wife and kids,and if I did spend that much time in the garage I'd be in the dog house, I'm jealous LOL
MP&C
Leonardtown, MD
At present its just a side gig, my nephew helps me as well. I do more rust repair than bodywork it seems......but I enjoy the challenge. And yes, I have experienced that dog house you speak of.....:lol_hitti
MP&C
Leonardtown, MD
Here's the continuing saga....
The second bend in shows a bit of a taper, from about 1/8" height thickness at the side, to about 1/4" on the corners, to about 1/2" in the center of the gate.
This will require the next set of MDF to taper off on the ends....
....and folded over as before. Because there is another reverse bend in about another 1/4", there was no need to completely shrink the corners flat. Just enough to provide that bend, and also shown is todays tool of choice for working the corners for this exercise.
And if you'll notice the lower section is now in two pieces, that comes from measuring incorrectly (wrong bend). About a 3/8 wide strip will be bent, added afterward and welded in place.
And the reverse bend after forming....
Comparison to the original. Needs a bit of clean up work, but should work fine.
And then the repair parts (the ones made so far...) trimmed and fit up for a better look..
Moving on to the stiffening bead in the tailgate, most were still intact but one did have rust issues, just like the surrounding metal.
To make this detail, a suitable "punch" is made by welding some 1/8 thick plate to the end of a 1-1/4" square tube. For the "die", the nicks and welding slag was cleaned off the vice, and it was opened to the correct size.
The next repair patch is centered over the tailgate and the approximate position of the stiffener bead is marked. The area is prestretched in the wheeling machine.
After some forming with my high tech punch and die, and some fine tuning afterward, the roughly finished product and a test fit against the tailgate...
rickairmedic
louisville ,Ky
Robert I always enjoy your posts . I am planning to start on my 1962 F100 unibody this year and have been watching your posts closely to try at the least to learn something as I will have plenty of rust repair to deal with on this truck .
Rick
MP&C
Leonardtown, MD
Here's the hammer form for the final piece of the puzzle. A notch is cut out for the stiffener bead to lay in...
I had a nice heavy brass flat bar, so it was put to use with the c-clamps, and the intial bends are formed to mark where the corners will be......
Then the points are trimmed off the corners and over we go to the Lennox with the Thumbnail shrinking die. Tonight I had a nine year old photographer helping for a bit...
The initial shrinking....
One thing I had to keep in mind, the dies need to be loosened up as you go, as the corners shrink and the metal thickness increases. Here's where I stopped for dinner... A bit more and we should be ready to tip the reverse bend..
And here's the rest of this evening's work, starting with the hammerform for the corner reverse bend detail..
After quite a bit of hammering....
...and a trial fit to the tailgate
MP&C
Leonardtown, MD
This evening took time to back up a bit, and fine tune the flange parts. The originals had an offset relief for the hinge bolting plate so it could sandwich between the inner and outer skin.
...and after a bit of hammer work, here is the result....
Next, to form the relief around the center bolt hole. The hole is marked, and a negative formed in a piece of MDF with a 3/4" drum sander.....
After using various punches with newly rounded tips, and a 3/4" dia piece of round stock as an anvil......
And the next bend is formed...
....and starting on the next side..
A_Pmech
IL
This is a great thread, please keep posting guys!
I've learned a lot about sheet metal work looking at your photos and descriptions.
:thumbup:
