tool_scrounge
Nice Rockwell delta 15-017 four speed drill press. Well worth $140. CHECK the pulley splines to spindle spines fit. Some can be very worn with lots of slop due to no lubrication.
Outlaw thanks for your input, wasn't exactly what you described but I have a full 3-1/4" of spindle stroke now.
Now if I can figure out how to add a deapth stop I'll be set
New project, as if I need another.
Progress 4E, 1.5hp 415v 3ph 4 speed gear drive with power down. A few things to fix, and considering cleaning it right up.
You must not have read the "WASN'T EXACTLY WHAT YOU DESCRIBED" part. The crank collar would have to be removed and reinstalled in a different position to use this as a deapth stop.
Spindle stroke was reduced because someone didn't put it back together right.
What Outlaw said. But from what I can see it is too much. At least it would be round here.This Atlas showed up on local CL. Asking price $100. I think it could be a fun project. Any thoughts? It says cord needs to be replaced, but who knows what else could be wrong.
'tween 1904 & 1907 Champion No. 200.
That's really well done...I enjoyed the look. Thank you for the link.A guy on youtube did an over the top restoration on one of those, you might find it handy.
https://www.youtube.com/playlist?list=PLNR9e5gIAR0dL90Qe17eYGCahDvLT-5MX
Nice, what is it, a 2 speed range gear box?
It's got that funky old time look too.
Wow. That dp looks pretty cool after watching the teardown and final build.
I wonder if any turn up over here.
cool!Yeah its a 2 speed box driven by the usual step pulleys to get 10 speeds, its a 9:1 reduction, pretty much the same as a back gear on a lathe. They made these from after WW2 until sometime in the 70's. Several makers made basically the same thing, Fobco are regarded as the best but the Progress are pretty good.
That's a nice drill! I just picked one of these up too, but I've discovered there are a couple of versions of this drill. Mine only has a 1904 patent date on it, where yours looks to have both the 1904 and 1910 dates. There's a few other differences too. Heavy little beasts, aren't they?
Here's a picture of mine in the barn where I found it, and on the ground at my house.
Do you plan to do a restoration on yours?
