hsvtoolfool
Somebody's clever grandad removed the handle from the big wheel, bolted a pulley onto the side, and made themselves a motorized post drill. I've never seen that before.
Those are nice presses. I had same model a few years ago, and can tell you that the missing spindle cover will cost you more than the rest of the DP! Good luck!
Saw that! Good score Ed!
recently picked up this 1899 Milwaukee drill press. I did the whole deal. but t=it drills a nice hole in style![]()
View media item 92098
Thats was always my Idea separate d/p's for wood and metalfinally found a clean and good priced Delta last month.
I also have this Craftsman with vari slo.
Debating wether to keep 2 drill presses or not. It is nice having one for metal and an oil free press to drill wood.
Debating whether to keep 2 drill presses or not. It is nice having one for metal and an oil free press to drill wood.
Boy Howdy, you can survive with two drill presses? Quick count I think I have five and in total some 17 spindles that will drill a hole. Two is just a start me thinks, but those two look like a real good start.
lg
no neat sig line
Dude that's awesome! I like the oil cups on the bearings. You should post some more picsrecently picked up this 1899 Milwaukee drill press. I did the whole deal. but t=it drills a nice hole in style![]()
Sent from my Moto Z (2) using Tapatalk
Great job! Was wondering about the table, would try it on mine but I don't have a lathe that would swing it. It's 21" royersford excelsior. It's a camel back, but newer than yours, I'm guessing 1920". It came already rigged with an electric motor.Ask and you shall receive!
It's a 21" Milwaukee, can't find anything about it really, only numbers I found are a "99" on the base stamped into it, either a date or a part number, nothing on the internet webs. weights 600-700 LBS and stands just under 7 feet tall, perfect for my small shop.
I redid the table. that was the big repair. It was a lunar landing pad, really bad so I machined it flat, removing about and 1/8" leaving most of the holes etc but making the surface true and bolted a 1/4" plate to it and machined the slots before machining the new surface true. Turned out awesome I think. Definitely recommend this repair to a table that is a total disaster! I put a nice old Holtzer Cabot induction motor on there. This machine has never been converted before I got it, I have the loose tight shifter and pulleys. But it is running nicely, drilling 1" holes!
View media item 92119
View media item 92118
View media item 92117
View media item 92115
View media item 92116
View media item 92112
View media item 92113
View media item 92114
View media item 92111
Adrian that looks superb. I'm almost regretting not painting mine black, thee looks sharp like that.
I finished up this Royersford 21" over the weekend.
Restoration thread here.
https://www.garagejournal.com/forum/showthread.php?p=7844324#post7844324
44, you need to take the "S" out of the https for imgur to work...
Nice restore! Makes me want to work on mine. Same model as yours. here's a pic of it when i purchased it. It came with all the parts except for the crank handle. Even has a period correct switch and motor although the pic doesn't show them. And i actually found the original crank for it a year ago on eBay lol.
Mike
Quite literally a barn find. I moved two horses to get this to my car. So far only knocked the dust off. Don't know a year and never heard of Rockwell before yesterday. I have been looking for a nice older drill press for several months. Seems to be just surface rust. Cast parts look brand new. Not one stray hole in the table. Someone took care of this.
The switch just seems.....wrong. Must be a replacement.
