Show us Your Vintage Bench Grinders!!!!
ncgun99
Eastern North Carolina
Picked up this Baldor 8250W today. Been looking for one for a while that was reasonable. Had to share it with someone other than the wifey…she wasn’t as impressed as I was. $100. Missing a few things but runs perfectly!
torqueman2002
gun99 - Very well done! That is one stout grinder, almost ~100 lbs & 3/4-HP.
You can find the missing parts on-line or OEM from Baldor and Mattblast has already made some/all the foil badges for my Baldor restore.
drivesitfar
Yep big Baldors are not cheap and I’m sure your bride will be more impressed once you take a rusty tool and sharpen or shine it up in a few minutes using it.
Isaiah6113
Oshawa, ON
So I sent him an offer Saturday morning and picked it up at noon.
Is there a 12 step program for people addicted to buying metal cabinets, grinders and vices?
I think I need an intervention, and my wife does too.
I think it's 60's vintage, very complete except for the water pot. The hook for the pot is there, so have a 1/2 9/16 box end hanging on it.1037742620.jpeg909897256.jpeg
Sent from my SM-T290 using The Garage Journal mobile app
1964
According to the Magic Decoder Ring
Those are fantastic grinders. I’ve had 9 of them over the years, managed to hang on to four. The only drawback is they are 7” grinders. 7” stones are still made, but the writing is on the wall I fear.
Matthew
Bugeyed Earl
Davie, Florida
There's an interesting part of a Rockwell guard on eBay (not my auction) for a not unreasonable price if you're in need, that's got to be tough to find:
royudc
Toronto, Ontario, Canada area
Hey Matthew, thanks for the year of manufacture info, I've bookmarked that page for future reference.
I bought a wheel for the other Triple Duty I have a little while ago but I agree with you, they could become scarce pretty soon.
This one has two brand new wheels on it but they're the softer green ones. I'm trying to be careful what I use them for.
Ron
exmaxima1
Midwest
Picked up an older Baldor grinder with the handle on top. All cast iron, including the rests, and weighs a solid 33lbs. Runs smooth as silk. Needs a plexi shield, but otherwise completely all original. I found info on it and attached the 1955 catalog listing---Type S7146. Btw, $57 in 1955 is worth $572 (10x) in today's money, so those were expensive grinders back then!
park city flyer
southern Indiana, U.S.A.
Hi guys I was wondering if anyone could help me identify this bench grinder? The grinder & motor have been separately sourced from yard sales etc. the motor is an old Gryphon, but I'm not sure about the grinder...
The grinder body has the letters 'G4' cast on the inside where the pulley runs.
Picked them both up for $25 including a steel mounting stand :)
All comments welcome...
It looks like a Prairie brand . I used to see them in the Silvo Hardware catalogs back in the '70's.
Tom
syahril
please tell me, what year this bench grinder producted ?
ncgun99
BeezaPilot
Florida
Still a way to go on it, need to make / find tool rests and get it assembled on a stand. Kind old man gave me the grinder, came out of the Collins Company factory back in the day. Cleaned it up a bit, babbitt bearings in good shape and run smoothly. After 30 years of tripping over an old Dayton motor with an 11:1 Dalton step down gear unit, I finally had use for it! (See! Never toss anything, right?). Disassembled the gear reduction and the transmission is like new inside! The grinder was designed to run on a 3" overhead leather belt at a fairly slow speed, so turned an oak pully and will use an automotive timing belt inside out to power it. With the 11:1 reduction and the larger oak pully, should give me about 375 feet per minute on the grinder. True the stones, add a water drip and I'll have a fine tool!
ncgun99
Out of town all summer but getting back to this thing. Finally got all of the replacement parts in. Need to put a new cord on it. Then paint. Probably go with tourqueman2002’s idea and get a paint match brush/roll on.C72421EC-7201-4CB9-9860-C9FBE5B85B5B.jpeg25DA67CF-9613-4CD8-9149-EA5736C36C0E.jpeg7E3C5A40-616D-4323-9615-5AE0EE5E6FD6.jpeg
jaycobie
Iceland
I recently finished cleaning up this old 1/3HP Milwaukee/Kingston-Conley bench grinder from circa 1949.
Replaced the starter cap (not pictured), bearings and some fasteners here and there. Added a fuse to the circuit, along with a screw terminal block from circa 1920 for easier wiring access and maintenance and also remade one missing spark guard.
It works beautifully, runs smooth and more than serves my small home workshop hobby needs.
I looked into getting vintage period-correct eye guards but they were hard to get and more expensive than what I could put together from modern components so I invented my own solution.
The grinder came with 1/4"-20 threaded holes for eye shields on either side from the factory, so I found some articulating camera-gear arms from smallrig that have 1/4"-20 thread screws on either end. Then got what's called a "cheese bar" (chunk of anodized aluminum bar with plenty of pre-tapped holes for camera rigs) to connect a sheet of polycarbonate to the arm. No machining or permanent mods to the grinder needed, just some drilling and shaping of polycarbonate and thats it. Probably cost me a total of about 130$ for parts for both shields (import costs to Iceland bump that up from what it would cost in the US)
Those arm are crazy good. They're more than strong enough for any kind of impact, they have built-in thrust bearings on the screw and are super quick and easy to adjust to whatever angle. I'm really happy with them.
Mintgrun
Kingston, Wa.
This is for sale on Facebook marketplace and I'm sharing just because I thought it was clever the way they used one side of the grinder to power a dust collector for the other side.
Sani-Grinder Model 704
- Drum sander -
For Orthotic shaping
$150
Listed 10 weeks ago in Seattle, WA
Tom
Ricky Joe
Roanoke, Va.
I have two grinders. First one is Sioux. Second one is Robbins & Myers.
lafester
Northern CO
I found another Stanley yesterday on my way home from NY. I can't pass up a pedestal even if I have to lug it 1700 miles. I love the power switch on this one and it will probably end up as a buffer. $75
I see the 557 in the early catalogs (1935-39) and not in the later 49-55 catalogs. I'm not certain when the lit eye shields became available... I would imagine this machine was one of the first to get them. I believe there is a government badge below the switch that I still need to get a closer look at.
Graeme
I have a few bit only 2 are interesting really.
I haven't done anything with either of these yet.
I have this old enox, bought as it was cheap. Done nothing with it. I had planned to use it as a buffer
But just recently I picked this old 10" black and decker up
This has already lost all it's grinder stuff and had some polishing spindles added.
It may be a little slow in the rpm though, but should have a load of torque and it came with some big mops so surface speed should still be reasonably high. Think the grinder is 1500rpm or similar.
I also have a foot powered grinder. A bit like a hand grinder but with a chain linked down to a foot pedal. It's a bit broken though, needs a fair bit of attention. Plan was to sort that and bolt it to the outside wall of the workshop for quick touch ups of the garden tools.
I'll grab some pics of that when I get round to sorting it. I think I may need some advice on that one, if I remember right some of the gears are broken and the freewheel is not in great condition.
snowpro90
buffalo,new york
Paid more than I should have,but I acquired this NOS Porter Cable #547 / 7” bench grinder. It will be put to work.
I believe Miller falls had a similar design.
exmaxima1
Midwest
Beautiful P-C grinder! AFAIK it was a novel design employing many of the Delta Rockwell features such as the narrowed (front to back) bell housings for more clearance, and the heavy cast rests. I've seen the Millers Falls version, and it is identical, but I have no idea who the OEM manufacturer was.
snowpro90
buffalo,new york
Does anyone know who built this blue point? I have one side cover amd am trying to cast another from it. Its not going so well. I may have to try to find one. The guards reaemble the shape of flavic3 post 1252. Thanks for the help. Great thread!
Hello. Very nice grinder! I just bought a Porter Cable bench grinder that is identical to your blue point. It is a 1/2 hp 7” model #547.
Miller Falls is another manufacturer that produced the same design.
snowpro90
buffalo,new york
Isaiah6113
Oshawa, ON
Hi Jay,
Others may have mentioned this; you might consider removing the wire wheel from the right side. It will absolutely chew up your pristine tool rest over time. And wire wheels should really be used without a guard, that way when it catches the piece you are working, the piece will get shot towards the floor rather than at your body or face, or rip things to pieces inside if it’s trapped behind the spark arrestor.
Just sayin’,
Matthew
PS Love those K-C grinders!
Isaiah6113
Oshawa, ON
- Drum sander -
$150
Tom
Miller Falls is another manufacturer that produced the same designs.
I believe all these were manufactured by Handler Manufacturing.
Matthew
Mississippi333
Corinth MS
I just noticed the same thing with the PC grinders. I just missed a 1hp PC on marketplace. It was identical.
lafester
Northern CO
My 1/2 hp Stanley is almost ready to get back to work. I hate painting but that white had to go... definitely not a show piece but functional.
Found some new SKF bearings, replaced the capacitor and added the vintage lamp. This will be a buffer for the moment so I am waiting on the extensions for that. I went with a 15 mfd cap but I am going to swap it out for a 20 like the old one for a little more power. I will eventually add some tool rests to have if needed. So far I like everything about these KC grinders except how hard they are to find.
lafester
Northern CO
I found another KC grinder today, this one is an Atlas version. Unfortunately the tag is pretty well trashed like my Stanley... It appears to be a later model with a printed logo rather then embossed. I bought a pair of lit shields off ebay along with another tool rest so I now have enough parts for a complete grinder. This one definitely needs some bearing attention, but otherwise will stay green for awhile.
I like these enough that I may try to do a halfway decent restore on one of them, but it will be slow going over the next couple months. I assume the round cap is a run capacitor like the other, but I need to get a tester on it to see.
