Show us your welding projects
E12-535iTurbo
The Netherlands
I like your wire brush with the curved handle. Where did you get it?
PCustoms
VT
Home depot paint aisle. It's not super stiff [i.e. won't knock slag off), I use it when I burn through a dirty spot and there is soot.
I made the hammer in college in the manufacturing technologies 1 lab.
Damian_74
Brisbane, Australia
Had the local sheet metal place bend the treads and laser cut the end pieces - cost came in at about $50 AUD a tread - and about another $20 each for Galvanising.
Will be dissambling it all in the next few days and getting the rest Galvanised - it is about $2.25 a kg and with the heavy sections that I have used it is going to set me back about $1000 - but will never have to paint!
readhead
Durango, Co.
Looks pretty good. The top rail tabs for the lower run are to high at the landing posts. They should be lowered one rise height.
Damian_74
Brisbane, Australia
YES - I noticed that after I stood back and cracked a beer :headscrat - Actually I need to extend the posts by one rise as it turns the corner - bit of a cut and shut, will be hardly noticed after a flapper disc and blending - will be fixed before it goes off to the Galvanises.
Griff93
Huntsville, AL
Recored an aluminum radiator for my skid steer. A new one was $1200 and no aftermarket available so I decided to buy the closest sized core I could find and make it work. Unfortunately I could only get close on the core size so I had to weld some small pieces of aluminum to the tanks. I went ahead and welded them on the inside.
Once I got that welded up, I setup the table to hold both end tanks and the core in the correct locations. The way this mounts, it has to be pretty close to the correct overall height or it won't fit in the existing mounts on the skid steer.
Closeup of welding on the tanks. The part on the left is where I welded over my tack weld. I still haven't quite figured out how to get those areas to look the same as the rest of the weld. Even if I don't put any filler down they don't freeze the same as dipping rod.
At this point I still have to put on the sides which mount the radiator to the hydraulic cooler and the fan shroud. I'll try to remember to take some more pictures.
curtrnev
Hose reel bracket and a support for a tool box that had been dropped by the moving company that moved our shop.
Magneto
"Relocated from VT to Middle TN"
GRIFF93 "[Closeup of welding on the tanks. The part on the left is where I welded over my tack weld. I still haven't quite figured out how to get those areas to look the same as the rest of the weld. Even if I don't put any filler down they don't freeze the same as dipping rod."
VERY NICE WORK GRIFF!
Hephaestus29
Indianapolis
Re: Show us your welding projects "DoAll Dollie"
Here's a few pics of my Dollie I'm building for my DoAll Vertical Bandsaw.
It's a ways from being done yet.
The picture of the weld is just one of the root passes, not a finish weld.
stsmytherie
VT
Second semester of evening welding classes winding down, trying to finish up some projects.
Practicing TIG'd plug welds (slow but can be done).
Wrenches for Porsche 901 transmission repair.
Jig for drilling holes in the corners of square-ish things.
Practice for welding up some table legs to mounting brackets.
amlee
Olympia, WA
Planning a trip to texas and needed more space inside. I modified a cargo rack (waay stronger and deeper) and bought a cargo box to fit it.
The swing away bike rack is aluminum. It works great! I have access to the box AND I can open the hatch to get in back too!!!
Griff93
Huntsville, AL
stsmytherie,
It looks like you're welding to hot and burning the steel. Try turning the welder down a bit and slowing down some. When it's to hot it affects the consistancy of the weld as well when thte puddle is washing out. Remember the more consistant your movements and timing are, the more consistant the weld will be.
Which version of a 901 you working on? I have a 71 914 myself.
Griff
stsmytherie
VT
Thanks for the advice Griff. I'll give that a try tonight. Building up some work table legs for the rest of the class.
Early tail-shift 901 off a 66 912 in this case. You may recognize the wrenches from Dr. Evil's transmission rebuild videos.
T
TLCObsession
Bellingham, WA
amlee - just make sure whatever is in the box won't melt when subjected to the exhaust. I used a similar setup on my gf's Highlander and it melted a few things.
mike528
Shelby county Ohio
Tire thumper for the car, made from scrap 1 and 2" shafts from work. Just need to get motivated to wrap the handle with a fancy paracord wrap.
amlee
Olympia, WA
Copy.....no candles in the box. BTW how hot are we talking? What should be avoided?
Hephaestus29
Indianapolis
Critique my mobile base for my DoAll please.
I'm wondering if I should weld these gussetts
on for strength and or to prevent possible twist.
The unpainted pieces are 3/8ths and the
Primered pieces are 5/16ths. I chamfered
All edges on one side to a 45 degree angle and
welded. I'll probably still put some weld
on the other side.
sqznby
Coastal NC
Nice hammer mike. You're a lot more patient than I am, polishing it up nice and purty.
I gotta now more about that get back whip. Where did you get it? It looks like a thick handled monkey fist.
Here's my beater
Just welded these up for a member of another forum
mike528
Shelby county Ohio
My block grinder came with a scotch brite wheel, that's all I've done as far as polishing it. The key is to start with something that doesn't need much to be polished.
amusick10
Picked up a ranch hand for cheap, had a bent bottom bar that I cut out and decided I wanted to add a receiver hitch for a rack.
After a beer or two I figured three would be better in case I want a more sturdy/steady rack or want to build a quail seat for the front of the old F250
ndr1968
Oklahoma
I keep that one in the car between the seats. Have a getback whip for the bike.
mike528,
What model year is yours? Mine's an '08.
I put the buckhorns on. Just doesn't feel right without them!
Damian_74
Brisbane, Australia
Stairs look great. Back on track with the hand rails I see. Are the bars in the rises a code thing there?
Yes - there is a rule stating that a 125mm sphere can't pass between the steps - My step rise is 175mm with a 50mm thick tread. With the extra thickness of the checker plate I would have JUST got away with bit but didn't want some smart *** with his clipboard wanting it changed - only added about $100 to the cost and by doing it now - none of the coatings have to be drilled into down the track.
Blazinzuk
Afton Wy
Helping my cousin do a clutch in his Dodge.
G56 isn't light.
I didn't even have to cut any of these. Already cut discards from whatever else
Didn't work like I planned. It worked better! Now I'm gonna mod it some. Cause I got lots of ideas. Going to attempt to use nothing but scrap I already have
In action
jimgood
Marshall, VA
Necessity is the mother of invention so here's a quick and dirty project. We were hosting a riding clinic at our farm. One of the participants backed her truck off this embankment.
View media item 60405
It was sitting on it's belly, driveshaft and fuel tank supporting a good deal of the weight of the truck. I was a little concerned that there was going to be some damage.
View media item 60404
I decided to try to lift it with my tractor but there was no way I was going to try to lift it by the bumper. The hitch receiver was directly under the bumper but I wanted to be able to keep the load very centered on my tractor. The only part of my loader that would get under the receiver without touching the bumper would have been the edge of a quick attach plate which is far from centered.
In about 20 minutes, I threw together this out of some 2" sq tube and some spare pieces of heavy angle. I tacked the tubes together to add strength. The lateral pieces of angle were there to flank the receiver tube. The center angle piece was to push against the receiver.
View media item 60403
I actually wasn't sure my tractor was strong enough to lift the back end of the truck but this worked like a charm. I lifted the truck and had the driver put it in 4wd low and creep it forward while I pushed.
And she's out! No discernible damage.
View media item 60402
