Show us your welding projects
stsmytherie
VT
Very nice welder cart. What did you use for turning, Rolex disc? Also what size is your table and how do you like it?
@shortykorte Exactly, I used a 2" fine scotchbrite roloc disk in the cordless drill. About 6 seconds at each position.
The table is a 24x36 pro table top from weldtables.com. Very happy with it so far. Perfect size for my small shop.
koditten
Midland, Michigan
Welded up this for a buddy. Half of a drive gate.
hEFBD1QODjkvkCGO5C9759RFADv-R2rbGIVISMH8tJ8xIGBzqiddHk-TdTJNwsUkWylbvxzOrb8esbVVepwwfNmg6sWXH-m_pWRwzoCtvTcJKUK6-VHSUKCBM5tPm6YQ5WnC3DZ192AAUWfX9aL8JaLZy7pM6U3hhH0cQ2YKS4bUuqzA2WLNmHXyVaAJZo_zcmLyVXIdeQCubvFPjwOrUC2ARQjbXlmk6aj3mFaD8MYaJN7iu6Px4tImqWW742VFG3vp3_qtRxqInuWHo0wvpkjCcXsv0CLxhk0hafmgKrqOMVcvtWCBoj4ccu8ObLA523ZpzazhAqRyNN9SEUqXc5WL_TcjncOJ1a5SWB4PBX7ByzohfJHVMCXSWgtmHVLstWs25DLiA58lwPftYCpjbxfUedOI25JslBnKKgvzFCPDBGZIOFkE0EPn-Ux6serxaAZcu2N9871_fa86Mm7biRNxfGueKzzH6Zm5B_4K7N4df_StPsBrQGW9wYEogFdD9P3afu9hc-jH40tEVdQG72EsAUkrPYoZS6tJWe9FjoeWoWf1St6o6OHCLRz1q-DpLXz5hpnWKcFQAViCT1RhGjZijaOzh7k0oZVrLJxprybTCt9P7oAR=w622-h828-no
koditten
Midland, Michigan
Here is a shot of the final product.
Looks pretty good. I did try to talk him into going full length on the angle brace, but his wife liked this better. We all know what the correct answer will be when that is the case.
full
chrispyny
albany, ny
Hey, that looks good! Lemme ask though, and please don't be offended, what is it? A gate for the garage doors of a home? I'm confused! Sorry!
stsmytherie
VT
DIY fab table clamps for my certiflat welding table.
Started by buying a six pack of cheap 12" bar clamps. Something like this, but a little cheaper via eBay: https://www.amazon.com/dp/B001OBTE9C/?tag=atomicindus08-20
Also a couple boxes of stainless 5/8" hex bolts from McMaster-Carr (https://www.mcmaster.com/#92240a798/) and matching nuts.
Cut the ends off the clamps at various lengths. Made a little jig to align the bolt heads and clamp bars. Commenced welding.
Less than $50 invested in all the components to make these six clamps, plus an hour of my time to cut and weld.
jeepinerdeep
South Central PA
Picked up a little Lincoln tig machine for my business. Knocked out a cart. Not a lot of welding in it, only about a dozen or so 1 inch mig stitch welds. I wanted it to be a little showy so I did it in Grand Cherokee "Granite". Still learning painting the hard way. Might make it in to a product.
larry4406
Northern Virginia
Jeepinerdeep - nice cart but the foot print seems small compared to the height. Is it top heavy? I'd be concerned with it flipping over if the small wheels hit something or went into a concrete divot.
jeepinerdeep
South Central PA
Doesn't seem to be, it's only 40 pounds up there. The whole thing is bigger than you think. Those are 3.5" wheels and the OAL is close to 32" I will be shifting the axle back 1.5" on the next one though. I guessed at the balance, and came close, but that could use some improvement.
shortykorte
Tallahassee, Fl
I was going to ask if cnc cut then I see table. Nice. What are the two big holes for?
thejimmy
Clearwater FL.
Nice cart, very unique design:thumbup:
Griff93
Huntsville, AL
Grand Cherokee with a trac bar mount ripped out.
Started out by cutting out a couple of plates and welded them onto the unibody for reinforcement.
Cut out a couple of brackets for the trac bar itself out of 3/8" plate.
All welded up. I doubt this is going to tear out.
zmotorsports
Northern Utah
Nice job on the trac bar repair.
Mike
Griff93
Huntsville, AL
I cut those plates out on our CNC plasma cutter so the holes didn't take much time at all. That is 1/8" plate in the above picture. The ZJ 'frame' rails are made from 14ga or 16ga sheet metal. I was trying to tie into a large area to spread the load. Figured more plug welds wouldn't hurt in that respect. I don't want it to go anywhere. I know this jeep will be abused in the future.
Heavy Metal Doctor
Mason Dixon Line
Oh, it won't hurt at all. I guess I just think about this stuff too much in the form of my work where most of the stuff is very solid, but no extras 'cause that costs time and money. The factory doesn't engineer in any more welding than needed.
smalltown
Western Maine
Just for my own education. Are plug welds simply holes in the metal that gets you more area to weld to the frame and make it a stronger patch ?
zmotorsports
Northern Utah
Plug welds, or Rosette welds, are holes drilled in the outer material allowing access to the base or parent material, trying to gain the same affect as resistence or spot welding sheet metal. Often times I have seen where the base or parent material was not fully fused and unfortunately the weld just sat on the base metal like a cold blob with no penetration. The key is to get the center molten and then in a slight circular motion introduce the top layer of material into the molten puddle resulting in a solid, unified structure or weldment. It is easier to demonstrate or show vs. explaining. I am sure there are some good youtube videos on proper Rosetter or plug welds.
Mike
Provincial
Near Salem, OR
I once dismantled a 1958 Ford Thunderbird, saving the body panels to repair another car. These were the first Ford unibody design, and were VERY overengineered. The inner fender panels are heavy gauge and structural, being spot welded to the frame and outer fender with spot welds about every half inch. It took forever to drill out all those spot welds!
The whole car was like that. I saved the rear quarter inner and outer panels, as well as the floorboards and rocker panels. I guess I was more stubborn than smart! :lol_hitti
Zeeman
Bartow County Georgia
Hey, I'm impress with those last two jobs. Nice work. I am not a welder, but hope to be able to come somewhere close to those welds one day. I just fix small stuff that breaks/just starting out really.
stioc
SoCal
Built the upper skid-plate to go with my DIY bumper. It was fun to build it.
Cleaning up the mess afterwards was back breaking for sure.
Ole Slewfoot
Freedom, CA
Fairy bell/gong for a 5 year olds birthday. I think it was 1 1/2 pipe, but I didn't measure.
Griff93
Huntsville, AL
I used a swag off road press brake in our 20ton hydraulic shop press to bend the 1/4". It works, not nearly as well as a real press break, but it gets the job done. I do need to buy a new ground clamp for that MIG. I keep thinking I'm going to buy a larger machine as that one is only a 175 so I've been putting it off.
Here's the diff cover all finished up and installed.
