A**hole, That Foosball table is ****! I haven't played in years, but just looking at yours makes me want to play again.
Where did you get the men? They look extruded. Did you design them yourself?
Sent from my SM-G920V using Tapatalk
That's the most ri-damn-diculous foosball table ever. I love it. How many hours do you have into it?
Here's one a did a few years ago. Built an entire front end loader for my 4wd mini Satoh Beaver tractor. (Mitsubishi bought them out in 1980, mine was a 79)
Most of the steel was scrap, free or extra cheap. Only new parts used were the hydraulics. Had about 1k in the loader and Bucket. Had 75 bucks in the quick attach and fork setup.
My uncle is a scrapper/horder and I scored this table from him FREE. Someone else welded it up and eyeballed the angles. I am 6'4" and raised the table up 8" by welding on some bottom parts.
Welded on old Harbor Freight wheels off a HF tool box. Spent a while cleaning the rust off the table.
Welded on a HF receiver and added a Vice/Grinder to one end with a thumb screw. Also added a angle grinder holder.
Invested in the whole thing: $50
Small compared to what many of you welders do, but I am a hobby welder with a small buzz box. Just picked up an old Lincoln Tombstone that I need to add a 220 volt outlet for. Have never stick welded.
Since photobucket went down I put the pics here directly, but I can't figure out why they rotated.
A few projects; I'm getting everything ready for moving to my new shop & making most things mobile...
Added a dolly and a press brake to my shop press:
Awesome little tractor you've got.
After changing oil in all my equipment last weekend and having no place to drain all the filters, funnels and pans I fabbed up an Oil Drain Tray. Just need to make the panel to mount it to the wall, a Funnel Rack, Shear a piece of Perf Stainless and get a piece of hose to run to the 55 Gallon Drum. Been a while since I picked up the Tig Torch.
I love long weekends.
View media item 71700
View media item 71701
View media item 71702
View media item 71703
View media item 71704
20171015_190655 by Trevor Patton, on FlickrI needed a tool tray for my new forge stand and forge. I had a grinder on this stand for years, but when I got the forge.... the old grinder just did not fit any more.. The tray made the forge and stand a better work area..
for the dr. Who fans...made from three layers of 16 ga steel and powdercoated in blue with led lights.
Made 100% of 1/4" plates cut out and welded together to make one big solid hunk of steel, sliding tube is 1/4'' wall and fixed tube is 3/8" wall. Screw is a 1" diameter screw jack I found in a scrap pile at a bridge project, has way coarser thread than most vises. Whole thing stands 8" off the bench and is 14 inches long, goal is to have 8" jaws. Currently weighs 30 pounds four of which are welding wire and the goal is 50 pounds or more when done. Been picking at it for a week now doing all the cutting with a 4.5 inch angle grinder![]()
Took a few tonight for scale, the little vise is a typical box store 4" vise and the drill is a regular 18volt Makita.
I’m hoping to redo the garage this winter and make it more streamlined..
