That is some large rebar.
The very beginning of my current welding project
I have plenty left to do
It has been a few years since I have welded. Hopefully I pick it back up quick. Wish me luck, I need it!
Sean
Looks like fun project.
Details?
It is for sure a fun project! It is a 1993 Lexus SC400 with a 5.3 LS, single 76mm turbo, backed by a TH400. It has its challenges, but that is also part of the fun!
Sean
Sean
I recently moved to a "hidden winch" setup on my old XJ. No one makes a bumper to go along with this, so I made my own. Turned out ok for a novice effort.
Great looking bumper! Where you at in AZ?
Always liked the early SC400....and a LS. Sweet!
LS and SC is a great combo! The old 1UZ was a nice engine, but not very modification friendly.
Sounds awesome. You had me at LS.![]()
More bugs:
Brent t nice work on the silverware art. Im stealing the ideas. Silverware is alot easier to find than horseshoes.
I do silverware artwork too. If anyone wants to try it , I buy my silverware at Goodwill. Ten cents each.
@BD1, Your work is what inspired me to try it myself. I see you are still doing it. Thanks for sharing.
Thanks guys ! Ndr1968 and Brent T , great clean work !!! That's how it should be. I always try to hide the welds.
I have a cheap HF buffer I use for polishing the silverware. Had it for years and still going.I normally don't buy cheap tools but for $35 it's hard to pass up for this light stuff.
Yes I'm still doing it.That second picture I made for a cute female hygienist. She recently graduated and I was impressed with her professionalism. So I figured I'd make it for her. She loved it along with the office people.
I'm still doing horseshoe stuff and yard art. Especially now that it's winter by me.
I sold lots of dragonflies at art/craft shows. For the eyes, I drill holes and plug weld on the backside. It has a cleaner look and can add heat marks / color too.
Your work looks much better than mine. I'm just getting started, mostly copying items I've seen online. The guitar player was my first "original" project. I think I'll do a bassist and drummer and maybe a lead singer down the road. It's kind of addictive once you get started and doesn't cost much. Finding out certain kinds of silverware work better for certain projects than others. I still burn holes through things quite often, but getting better. I haven't done any grinding or polishing on anything I've done yet. I've been wondering if I can get rid of some of the heat discoloration with a little work. Looking at your pics, I see where I have some room for improvement.
Thanks. Choosing the right silverware helps. I have a huge assortment in stock because each piece is different. I'll share the way I found out to be the easiest. It can be extremely difficult to prevent burn through or discoloration. Each piece is a little different but same principle. This maybe easiest to view on tablet or laptop.
I add a piece of silverware sometimes to weld too like on the turkey. The turtle and skier, I leave handle on and weld to it. Welding directly on the shell will discolor it and possibly burn through as you know.
I also use a clamp from a battery charger for a ground. I add 10 gauge stranded wire to clamp and other bare end I stick inside copper tubing. Pound or press flat and stick that into ground clamp. This should definitely help. Let me know if I can help.
That turtle is cool.
Thanks for sharing the underside of "Mister Turtle"! You can see how I burned through trying to steal your idea when I first saw it.
Yeah. These are from my "bug" phase.
Oh no doubt the frame will remain rock solid forever. With everything triangulated it's a strong as it gets. That's why I just wondered if the fire pan played nice. Also did you make provisions for water drainage. When I built our fire pit I cast a 1-1/4" schedule 40 galvi drain into the center. Then after I placed the fired box in forced the center down about a 1/4" then welded the transition. Btw, the pit (for lack of a better term) is a 3 course high 8" split face block with brick cap, one of those forever projects. To date she won't hold water so at least that part turned out good![]()
What gauge is that?
