Show us your welding projects
Old Man Roger
Palm Coast Florida
Oh yeah... i found something stating the load rating of the Carlisle Turf Glide tires was 410 lbs/ea... my airplane is about 1,000 lbs with a full tank of fuel and me sitting in it; but I figure the wing is supporting the vast majority of the airplane's weight if you finesse the landing and 'fly it on,' until you're slowed and you let the tail down... and then you've got the tailwheel supporting some of the weight and you're rolling nice and slow. I don't know what load factor they designed into the tire before declaring it good for 410 lbs, but I'm going to try my best to achieve a tame rate of descent upon landing. I'm sure they didn't design this golf cart tire to accelerate from 0 to 60 MPH in a split second, either.
I saw a lot of Kitfox, Avid, and ultralight pilots using these tires so I figured I would throw caution to the wind and give them a chance.
Your suspension worried me, now your tires are worrying me..lol A little bounce or bump and you‘re overloading your tires. A blow out at 30 or 40 mph in the grass, and you might be on your nose. :scared:
Mr.N
Mpls, MN
Can we please talk about something non-controversial like chemtrails or Building 7?
Planet X is now a primordial hole.
In Moab at EJS, looking around the jeep and found the crossmember was broken into two pieces. Friend had a Hobart 140 and flux core, I had an angle grinder and some extra steel. The crossmember is from a long time ago, not my best work but I was happy with the parking lot fix.
mattthemuppet
San Antonio TX/ Spartanburg SC
I built this taller landing gear for my airplane (experimental/amateur built Fisher Celebrity) after finding out the hard way that it didn't have enough propeller clearance to land in a tail-high attitude, as one typically likes to do on hard surfaces. I took it from ~4" clearance to 18" clearance now with the fuselage leveled.
Absolutely beautiful work! My only suggestion would be to use corner radius endmills for any transitions so you don't leave a sharp corner that can act as a stress riser. Mainly for those U shaped clevis pin type brackets. Other than that, fabulous!
colindoyle
Minnesota
Working on building a stainless frame to support this teak swim platform salvaged from another boat. My "uncle" (my dad's cousin) bought this Bruce Roberts homebuilt trawler with the intention of completing the Great Loop within the next couple of years. I helped him retrieve it from New Bern, NC last fall, and it's been sitting in my shop all winter. We're putting some final convenience and security touches on it before it moves to a marina in St. Paul in the coming weeks, and he plans on spending some time this summer cruising up and down the river, maybe as far as Lake Pepin, acclimating himself to the boat and collecting performance data.
Guy's in his late 70s and has served on the last couple of diesel submarines in the US Navy fleet, performed over a hundred transatlantic crossings ferrying light aircraft, then wrapped up his career flying Cessna Caravans for FedEx. The last few years, he's been towing a rail speeder car all around North America and participating in NARCOA runs. Serial adventurer.
Beerhippie
Far NE Oregon
Nice save on the swim platform! That's not just convenient, it's a good safety feature if one needs to re-board of transfer from a dingy in rough conditions.
I'd never heard of The Great Loop. Now I want to do it! What would it take in a kayak--three, four years? I'll have to ask the boss for some time off.
Bob Heine
Boca Raton, Florida
Colin, did he take it to Alaska? The Alaska Railroad doesn't connect with any other line but it traverses some truly spectacular scenery.
I rode the Fairbanks -- Denali (Mt. Mckinley back then) trip in 1957 and the scenery left a permanent video in my brain.
colindoyle
Minnesota
A few years ago, he asked if I could modify my 4-place wedge car hauler trailer to carry a bunch of rail cars. I don't remember if he was trying to organize a run in AK or if it was something up by the Hudson Bay. I don't think he ever made it up there.
I believe he's done the Cumbres & Toltec run and that Durango-Silverton section, amongst dozens of others.
sqznby
Coastal NC
Man, that platform looks great, nicely done. Wish I got SS work like, it's all anodized or raw for me. I think I'm starting a bracket tomorrow.
Too funny you came to New Bern NC for it. Do you come out this was often? I'm at the coast 45 minutes east of New Bern in Morehead.
colindoyle
Minnesota
Never been out there before, we just made the trip to retrieve this boat. We put it in the water in New Bern, then stopped near Hickory to rendezvous with the previous owner, who had operated the boat much longer than its most recent owner. We put it in a lake there and douched out all the brackish water from the coastal port. Beautiful part of the country, and I never skip an opportunity to take a road trip somewhere with Waffle House.
Messing with the deck structure now. I'm not really able to put much of a vertical gusset feature under the center of the deck due to the exhaust placement, I figured my best defense against deflection is to make the flat part of the frame into a trellis and hope it resists twisting. Of course I'd love to support the whole thing from above with a couple of tubes in tension, but that's kinda antithetical to the purpose of the platform. I'm probably overthinking it, I weigh about 275 lbs and have a habit of overbuilding this type of thing.
My uncle is talking about renaming the vessel from 'Favrile' to 'Cat Sass' and painting a Cheshire cat on the stern. :lol:
Nortonscustom
They're one-piece Douglas 6" x 5" W with 2.5" backspace. I milled an additional three holes in each one because I didn't feel super confident having three 1/4-20 bolts holding my wheels on.
I got them from BMI Karts, part number was DWT706-04
Thanks I'll check them out.
Nortonscustom
Our spring "camping" trip was coming up and Mrs. Nc always complains about the water at this campground. So needing a break from the current projects I went to Menards and picked up a couple whole home water filters.
Bent up a frame and cut a mount.
The base un-pins and pins to the side. That way the filters can store flat in the camper.
Added fold down ground spikes. They turned out to be completely unnecessary because it weighs a ton once the filters are filled with water.
Mission success! No complaints about the water. Happy wife = Happy life.
Firstram
Working on this tree fort inside the farm shop. Going to be my office on the top and a bathroom, mop closet, store room on the ground level. Real slow burn, I pick away at it as time allows between important work.
How did you twist those spirals? They are very clean and don't have any tooling marks.
Hey how, don’t scare him away. I want to see what he makes next week!
Every Forum needs someone that inspires everyone through feelings of inadequacy. Fortunately, we have more than a handful of shining examples!
zmotorsports
Northern Utah
Fantastic job and very creative with the base being able to stow away. Also the spikes being retractable is a nice touch.
I built a water filter setup for my in-laws about 10 years ago with an aluminum base and frame but it was nothing like yours. Great job. :thumbup:
NUTTSGT
Northern Central Ohio
Harbor Freight has great F clamps for $25 ea. They are perfect for cutting up!
Menards are $30 plus 11%rebate making them $27.
The threads are copper coated as opposed to the black oxide of the HF models. Mssterforce claims welding berries won't stick to the copper.
EDIT: picked up another clamp last night. A picture of the label.
whitesco
Pittsburgh, PA (ish)
May have to steal this one - nice work!
Firebrick43
West central Indiana
Very nice. Plus with those ground spikes you have a very nice tool to fend off pesky bears!
The last thing I heard last night Officer was “Back you devil! , Back I say!”
This morning we just found shoes with the feet in them and this very nice portable filter setup. Do you think I can keep it?
ObnoxiousFumes
Southwest Sask
Reminds me of that old saying:
"What doesn't kill you makes you stronger. Except for bears. Bears will kill you..." 😄
Nortonscustom
@Nortonscustom that is a great idea and execution. Are you running two different filter packs? Like one for most of the sediment and then a carbon one for taste?
Ron
Ron that's exactly what I did. Was genuinely surprised by how much better they worked compared to the standard Camco inline hose filter we've used forever.
Not to derail the thread, but a funny bear story. Couple years ago we were boondocking in the mountains of Utah next to a creek. Look out to see a mid sized black bear walking along the creek towards us. He walked right up the the window, looked at the back of my truck, turned and took a huge dump right in front of the camper door. Then kept on walking down the creek. To this day I'm convinced he saw my Illinois license plate, shared his opinion and went about his day.
Bob Heine
Boca Raton, Florida
a funny bear story
@Nortonscustom, we spent a day fishing the Yellowstone river in 1956 when I was 11. Not catching anything, I went for a walk in the marshy woods nearby. Stepped carefully from dry spot to dry spot until I came upon a GIANT (probably a cub) black bear standing on the other side of a fallen tree. I froze and thankfully the bear turned and walked away (I was pretty skinny back then). My 10-minute dry route into the woods became a 1-minute, very wet dash back to my fishing spot. I think it was my introduction to adrenaline.
whitesco
We have a similar setup - Beech Lane is the brand I think (bought on the Amazons and I mention their name b/c of good customer service experience we had with them). Two filters, one 5 micron and one .5 micron/carbon filter. We still run the Camco filter ahead of it which is 20 microns if memory serves, just thinking it may extend the life of the other two. 🤷‍♂️
I don’t have the bending skills and am still trying to teach myself to weld so mine won’t be as purrty but I’m stealing your idea!
jblnut
In the Middle of MN
Back to welding stuff !!
I have had some short pallet racking uprights around for too long and finally found a use for them. I acquired a few beams and some heavy decking and went to work. I found some old tin and a few beat up racking beams and welded it all together.
Goobered some angle irons on to assist in stacking them up.
Once they were built it seemed logical to fill them with firewood.
My S300 had its shorts full moving this over here. It didn’t fall on its face but was close meaning there is well over 5k in this rack. The top one stacked back on perfectly which means there was very little or no spreading of the uprights once it was filled with wood. Now that I know it works I just need to build 30 more lol
