Show us your welding projects
colindoyle
Minnesota
I built this taller landing gear for my airplane (experimental/amateur built Fisher Celebrity) after finding out the hard way that it didn't have enough propeller clearance to land in a tail-high attitude, as one typically likes to do on hard surfaces. I took it from ~4" clearance to 18" clearance now with the fuselage leveled.
I worked from the outside in, first making these wheel hubs to mate 6" kart wheels to ATV brake rotors, then made caliper brackets and these clevis things, which will engage telescopic struts that contain bungee shock cord, like a Piper Cub. The shock cord is the 'spring.' The step milled into the clevis engages a matching step machined into the back of the axle shaft, allowing it to be retained in the spindle bore by one big bolt in the center (there's a video.)
It should make sense after the next post or two...
IMG_8230.jpegIMG_8268.jpegIMG_8348.jpegIMG_8363.jpegIMG_8374.jpegIMG_8384.jpegIMG_8390.jpegIMG_8396.jpegIMG_8401.jpegIMG_8405.jpeg
colindoyle
Minnesota
It's all 4130 chromoly tubing in the gear legs and cabane, and the axle shafts are 4340. TIG welded everything with ER70S2 filler rod.
I had some trepidation about extending the gear legs without increasing the width of their attachment points under the fuselage, as they're acting like a more effective lever now to twist their mounting bosses. I made a little cross brace that spans the rear pickup points and loads in compression against any forces acted upon the tires. Haven't made a carrier landing into a gopher hole to test it yet.
IMG_8409.jpegIMG_8449.jpegIMG_8455.jpegIMG_8462.jpegIMG_8518.jpegIMG_8579.jpegIMG_8581.jpegIMG_8603.jpegIMG_8605.jpegIMG_8606.jpeg
Beerhippie
Far NE Oregon
Now for something completely different!
As in, 15-minute shade-tree fab/welding.
I needed a post driver as I had to sink an 8' ground rod for a lightning ground today. I didn't have a driver handy, nor an acorn that would fit my Bosch rotohammer. So off to the boneyard!
A 29" piece of 3" OD well casing--left over from a fence project years ago--and some random scrap of 1/2" plate, some grinding, some time making sparks and:
"Drive it like you stole it" was one of the mottos of a fencing crew I worked on years ago. The other ones aren't fit for a family-friendly site. I was reminded how long ago it was that I spent hours driving posts, but the rod is driven, wire is hung and that new antenna at the highest point of our tallest building at the brewery is now grounded. We had a real boomer come through Sunday night and I was feeling nervous about having an un-grounded lightning rod.
Anyone need to drive a few T-posts, you're welcome to borrow my driver. I'll bring the beer, a lawn chair and some advice.
Beerhippie
Far NE Oregon
Nah, handles on a post driver are for newbies!
Not that I intend to ever use it much!
Your work is AWESOME! I used to be a better welder than I am now, but never anything like that.
PS: Alaska Bushwheels used to be right up the road from me.
M.Brane
1 hr N/W of LA LA Land
+1 on the awesome work. Always enjoy reading your posts. Hope to figure out the whole TIG thing one of these days when I have the quality time to spend with the welder I bought a couple years ago. I can stick things together OK, but still in the hack stage.
colindoyle
Minnesota
I just had to force myself to use the TIG when I would've much rather used MIG. Gotta accept that it's a slow process, but the results will be worth it eventually. Prep is huge - remove all mill scale, whether mechanically with a DA sander or pickling in muriatic acid, and then rinse in acetone before you even think about turning on the welder.
I'm still welding with the Lincoln Square Wave 175. When I get good, maybe I'll upgrade to something with more screens and dials.
Beerhippie
Far NE Oregon
img_8409-jpeg.2095928
I'm using the same gloves. Why don't my welds look like that?
Asking for a friend.
Old Man Roger
Palm Coast Florida
All assembled. I stuck the brake calipers upside down to shroud the hoses from damage when bouncing on a turf runway. Bleeding them kinda *****, but you don't have to do it with any regularity.
I didn’t sleep much last night, so I admit to not reading and just looking at the pretty pictures..lol But that bungie cord suspension scares me.:wtf:
Beerhippie
Far NE Oregon
You didn’t tig weld your fence post driver?
Up until a few years ago, I TIG welded everything and very rarely pulled out the MIG--mostly for big structural things. Nowadays, it's the other way around, and I use the MIG for anything I can. Much faster set-up and prep and just easier all around. Not near as pretty, but then, my TIG welds weren't all that pretty at the best.
I miss the sanitary welding. Thin-wall 316L tubing, fitted to a gnat's *** and fusion welded with the tubing flushed and supported by argon. Done well, the welds almost disappear. Unfortunately, it requires very good eyes--joints fitted to a gnat's *** are hard enough to see without the welding helm--and very steady hands. I no longer have those. We hire our sanitary work out to a fellow who has family here and comes to visit for the holidays.
colindoyle
Minnesota
Today's welding project... they can't all be bangers.
My dad went to use his little utility trailer today and found the coupler latch all blown apart due to a broken draw-down bolt (or whatever that thing is called.) I don't recall damaging it, but I probably hit it while plowing snow or damaged it while moving it around with the forklift. Must have been unaware or too swamped to deal with it, it's uncharacteristic of me to leave something damaged.
IMG_0345 Medium.jpegIMG_0346 Medium.jpegIMG_0347 Medium.jpegIMG_0349 Medium.jpegIMG_0354 Medium.jpeg
kaymccampbell
Upstate New York
Those perforated bolts stretch over time and finally fail. It's common.
colindoyle
Minnesota
EZGO Marathon I use around the farm. Stretched the wheelbase by building some framework under the seat that moves the drivetrain mounting points rearward, installed Suzuki LTZ400 front suspension and ATV wheels/tires, built a simple manual-dumping stakeside body, incorporated a 2" receiver hitch, built a front basket and installed a pair of old Meyer plow headlights. Pretty much all leftover material from other jobs.
I have a 2 cylinder Kubota diesel from a Carrier APU and a Yamaha G2 axle that I need to put in it... sick of dealing with the 2-stroke gas engine.
46530010_386998191869681_1470903704596542021_n.jpg47080206_378168276276053_9050017678439097811_n.jpg47327039_229785814590053_5880194138578430526_n.jpg47583600_287452395450006_4114829315001964044_n.jpgIMG_8107.jpgIMG_8108.jpgIMG_8109.jpgIMG_8120.JPGIMG_8121.JPG
colindoyle
Minnesota
Keep in mind, I'm just sharing the highlight reel. Most of the junk I do is a lot closer to the trailer coupler than the airplane landing gear.
What are you constructing out of that pile of tubing?
LXCam
I’ve got a footprint issue in a horse **** technology room. I’m installing a little 15kva ups with an extended runtime battery cabinet. Problem is mounting them side by each like they’re supposed to be encroaches on the required clearance for some electrical panels. So this is nothing more than a stand to get the battery cabinet over the top of the ups.
PugetDude
Superstition Mountains, AZ
Hah! Finally something I can relate to. :D
Nortonscustom
Pretty common design derived from the Piper J3 Cub. There's a positive stop to limit travel if the bungees snap, and they're supposed to be replaced on a calendar interval. The striped bands woven into the shock cord casing are color-coded to indicate date of manufacture.
Did you use one or two piece kart wheels? Getting ready to build new bungy gear for my little Kitfox and picked up the same Carlisle tires. Looking at wheel options now.
colindoyle
Minnesota
Oh yeah... i found something stating the load rating of the Carlisle Turf Glide tires was 410 lbs/ea... my airplane is about 1,000 lbs with a full tank of fuel and me sitting in it; but I figure the wing is supporting the vast majority of the airplane's weight if you finesse the landing and 'fly it on,' until you're slowed and you let the tail down... and then you've got the tailwheel supporting some of the weight and you're rolling nice and slow. I don't know what load factor they designed into the tire before declaring it good for 410 lbs, but I'm going to try my best to achieve a tame rate of descent upon landing. I'm sure they didn't design this golf cart tire to accelerate from 0 to 60 MPH in a split second, either.
I saw a lot of Kitfox, Avid, and ultralight pilots using these tires so I figured I would throw caution to the wind and give them a chance.
