That is incredibly beautiful. My wife might even let me keep it in the house!
Sent from my SM-G920V using Tapatalk
Bumper for a buddies jeep
Thanks Mike!Nice. I'm a fan of Jeep bumpers that are NOT mass produced.
Mike.
It's not much of a project but I was glad to have the welder when the inspiration came.
I had a customer, on a weekend evening of course, that had oil pressure drop on a 16 cyl. 9,400 CUID engine.
They tore into it trying to figure out the cause, checked the main and rod bearings, all good, pump good, etc.
They put it back together and decided to start getting a swing engine in order and run this one till it goes.
To make a long story short, one of the mechanics went over to a bypass valve and whacked it with a hammer and the pressure bounced. He started hitting it and soon the pressure came back to normal. Saved them and easy $400,000 in parts and downtime.
I was in the garage and looked at a few hammers I picked up at a garage sale and the rest just started happening....
No there's a great combination do you keep the wood close to the stove or the fuel cans as far from the stove as possible?Threw this rack together to tidy up the garage since there was jerry cans and firewood scattered around.
thankyou I thought about that , I was wondering if I need to put it up on blocks? My old wheels the rubber just fell off.You will need to provide some way to jack the frame of the rotisserie up to take the weight off those wheels. They roll really nice, but with a constant load in the same place, they will flat spot. Otherwise - agreed - never weld casters on.
Repaired a damaged tongue and installed new Coupler, jack and top plate.
Great work, my only concern is the Jacks closeness to the hitch, I'd suggest next time place it closer to the deck to save a tailgate or two.
75 gallon?
The tailgate is 8"-10" away from the Jack when down. The area behind the jack will have a tongue box that houses a winch. I took all this into account when laying out the jack location. FWIW, the equalizing hitch is much longer than a standard hitch giving plenty of room for the TG.
Thanks for your input.
dude... you're not a hypster photographer , grow a beard, shave your legs and only then the pictures will look wright
