Show us your wood projects
volvo
PNW 45th Parallel
This was at the Portland Roadster Show this past weekend. I remember another thread on it but couldn't find it. Enjoy, fully drivable 1932 Ford
Alchymist
Central PA
Present for the wife's upcoming birthday. Black walnut journal holder. Designed to sit on the library shelf between other books; can be laid on it's side if desired.
billcole
Northern Michigan
Posted in a different thread, but I guess it belongs here. Its a serving tray for the wife.
superdutymike27
SE Wisconsin
I enjoy doing it and someday they will end up in the garage when it's done. I would like to recreate an old service station in my garage one day just on a smaller scale.
KCarGuy
50 miles outside Chicago, illinois
I was finishing a Oak Plywood Cabinet for my Wife.
Our Thought was to have a Piece of Dark Granite Cut and installed on top.
But, I got a little more creative...
Cut and Installed Slate Tiles, used a Darker Gray Grout.
Trimmed it out with Red Oak.
Used 5/8" Plywood for a Back Splash, routered out the center so that the Tile and Oak Trim would wind up level.
Set and Grout the Tile, so the Grout lines all Matched.
Sealed everything and trimmed it out with Red Oak.
Added Gray Outlets on each end with Oak Plates.
Now I am Trimming out the Rest of the Cabinet with Oak and Need to stain and seal.
I picked up some old Vintage Hardware from the Flee Market, so Once its complete, I will add another Photo.
She Loves it.
JMartel
Seattle, WA
Jewelry box for the wife.
Just picked up a bunch of red oak today for some end tables.
JMartel
Seattle, WA
Just cut some thin strips of curly maple and walnut. Glued them up, then made a border around the center walnut section. The outer edges are the sides of the box. Glue it up so it's a completely sealed box with no lid. Then cut the lid off with the table saw.
You can't really see it from that photo, but the top is beveled with an 8 degree angle all around it and then sanded the edges smooth.
64dragnwagon
Northeastern Tennessee
I have a question for you woodworkers, I need to learn how to make these type of joints. I have a router table and a 24 piece set of router bits and have a pretty good knowledge of woodworking. I am assuming that you need a traditional bit like a roman ogee and another bit that is a reverse pattern of the other to make them fit together. The problem is I have searched quite a bit and have not found anything like this available. Please give me a clue where I can get a set, or if I am wrong please set me straight. Thanks
cnc-me
MI
Search for "cope and stick", its usually done with a Shaper, but you can get
router bits for this also.
shoot summ
You need a cabinet door set, or as stated they are typically called "cope and stick", or rail and stile. You will also need a router table.
http://www.woodcraft.com/Category/2082411/Rail-and-Stile-Router-Bits.aspx
64dragnwagon
joe6749
minnesota
I am sure there is a new yankee workshop show that would show you how to make Cope and stick joints.
earlthegoat2
SE GA
Here is a recent and continuing project.
Ripping to width.
Gluing up one side.
Initial flattening.
Its going to be a specialized joinery bench with a twin screw vise as well as a smallish wagon vise for a tail vise. Using only hand tools.
Alchymist
Central PA
Ripping to width.
Gluing up one side.
Initial flattening.
I see blisters in your future! :D
signcrafter
Ripping to width.
Gluing up one side.
Initial flattening.
Is this in your living room?
earlthegoat2
SE GA
What's that on the top of the board in the ripping photo? Something to keep the kerf open?
Yes. The SYP I was using wanted to spring back on the kerf. That is a CMan screwdriver holding it open.
It WAS in my living room. LOML and I had to live in an 800 sq ft apartment for a year while we were closing on a house. Now I live here.
No garage, but it is in the works. In the meantime there are two (count 'em) two living rooms in this place so one of them got turned into a handtool only woodshop. So technically, I am still building wood projects in my living room. Yeah, she is understanding.
Keep on building.
RivennHewn
PNW
Turned this out yesterday, got a coat of finish on it today.
Shark's vertebrae cane or walking stick.
I've seen a few antique ones. They can be kinda pricey.
coolreed
Oklahoma City, It's a Windy Heat.
My Split Top Roubo Woodworking Bench.
Made with Solid Ash, Bubingua and Pecan. Leg Vise and Wagon Vise utilize Benchcrafted Hardware. Not pictured but on the back side is a Veritas Pattern Makers Vise. Finsih is Tung Oil
This is a Knife Display Case I made using Birds Eye Maple and Bubingua. The knives are a matched set Bowie and Arkansas Toothpick. Both feature damascus steel blades, mastadon ivory handles, and mulkamay hilts.
Cabinet I made out of solid Zebrawood.
rslaback
Westcentral Wisconsin
This is a rocking horse I made 7 years ago for my son's first birthday. I have always hated 1 dimensional wooden rocking horses so this was perfect for me.
The two outside pics were taken this morning. The pj picture was on his birthday and the cowboy was taken at about age 15 months. You probably don't need to see the 15 month picture, but I am a dad and I love that picture.
Carguy99
Warrenville IL
framed out the new windows. The installers did an awful job I had to redo it. I think it came out much better. Now 15 more to go.
Alchymist
Central PA
Tried something different - I call it electric wormwood. Did a test panel, thinking of using it for drawer fronts, raised panels, etc. Perhaps even picture frames.
