Show your Millers Falls tools!
Pexto
Here are some Millers Falls tools that I inherited from my dad. The drill press vise includes an angle jaw insert, I'd never seen one like it before.
IMG_20211219_214002678_HDR.jpgIMG_20211219_214714750.jpg[/ICODE]
WilsonLR
FL
Just take it easy with the impact driver. A couple of light blips on low power/low air flow should do it. Increase as necessary. It should spin right off, unless something is really boogered.
I tried this but it did not come off. It only advanced the motor in the direction it normally turns. Ideas?
Nutria
Eastern Sierra
Confirming that you checked to see if there was a machine screw securing the chuck? If not, do check. If there is a screw, it should be left-hand, but you should use the impact wrench in reverse. I do this with the drill out of lock position. Even though the armature can spin, the impact blows are fast enough to break the chuck free. You can try locking the drill. I'd be extra careful then about force applied, but it would be worth a try if nothing else is working. Lastly, is there any corrosion? You could apply Kroil or similar, I suppose even if there isn't corrosion. But the impact driver should pretty much break any crud free.
MisterEd
Florida
A complete set of Letters (3*16") in the box and Numbers (3/32") minus lid.
bonneyman
Desert SW
I had a bottle cutter kit as a teenager, and lost interest after trying to make some items with it. But now I'm thinking such a kit might prove useful. I'm glad I've got a few of the oldster glass cutters around.
Beware, they are a ***** to use, unless you need a perfectly odd sized hole. Most true auger bits work easier. Is it a square tang or round stock?
My Old Tools
Hamrick Lake, TX
Most of us know MF made those wonderful "egg beater" hand drills, but I've discovered alot of other tools marked Millers Falls. I was surprised not to find a thread on these - maybe I overlooked it. Post up what you've got - I'd like to see 'em!
Here's a 2A drill I was given recently. The man of the house passed away, and the widow knows I like tools. So she let me have it. I did a little clean-up and touch up paint, but left alot of it as is. One bit still left in the hollow handle.
Another Millers Falls boring machine I restored. I had to make new shafts. chuck base, and legs for this one.
indyjeepman
Duluth, GA
Here's one that I found in a box of Dad's stuff a while back and just put it on the bench. I still have no clue WTH it is used for. Maybe a scraper? Millers Falls No 51. Was bought at Sutherland Lumber in Indianapolis, probably circa 1965 or so.16561113706667971671598804977938.jpg
indyjeepman
Duluth, GA
Paint or wood scraper. Catalog says wood scraper. You might be missing a blade, so the one remaining may slide around a bit.
No it's all there. I suspected that may be it. That big hole makes a good place for spider eggs. Found out this morning. Got hundreds of tiny ones that came out and are all over my bench. Lol
btrnuthatch
According to oldtoolheaven.com this is a:
No. 109​
b109sm.jpgUniversal Angular Bit Stock
Single universal joint; rod-and-thumbscrew adjustment mechanism; main casting is japanned; bright parts are nickel plated; Barber Improved chuck with spring-type alligator jaws.
Supersedes Anthoine's universal angular bit stock. Used with bit brace or breast drill as an extension or angular borer.
Illustration from 1915 catalog.
Millers Falls Universal Angular Bit Stock #109 .jpegMillers Falls Universal Angular Bit Stock #109 left.jpeg
Instead of using in an art project, seems like it should belong to a collector. I'll post in classifieds later.
The Bean
Delaware Valley (SE PA)
Time to wake this thread up again!
Hey! I found this nice old Millers Falls #188A push drill in my tool box today. Must have been my grandfather's. Took it apart and cleaned it. Almost lost the spring, eek. I don't have any of the bits...they need to be rather short. Anyone know a source?
genog
Silicon Valley
A great friend of mine had a box full of chisels
His widow sold a bunch of them at a Flea Market for a dollar each.
Gads! :eek:
There was only this one and a few Buck Bros left
The Bean
Bummer. The Goodell Pratt, and Millers Falls drills took a different base bit than the Stanley’s did. I think they are the same length as the Stanley’s at 1+” long. I see 20x Stanley for each MF style bit. I give them to my buddy who collects GP.
See the new style here.
The 188A has a four jaw chuck, so I think the round shaft bits fit best. I suppose I can grab a drill bit set that includes 1/16 thru 11/64, as long as they are 2" long max.
Is that what's called jobber length?
I just remembered that archive.org sent me an email a while back telling me they had a *.pdf file available on "The Goodell Brothers...."
Looked interesting but I deleted that entire email account recently.
I don’t know that the 4 jaws in there will open wide enough to grab a round bit of much size. It’s made to grab the little flat tab at the end of the bit, to give a positive bite, not a round bit.
This is what the **** end looks like. Your 4 jaws fit the tabs shown, not the round shank.
Teethsmasher
Maybe someone could help me I inherited this from my grandfather and I've simply not seen one anywhere else ever. The electric drill stand and not the drill itself. It was filthy and rusty when I recieved it so I cleaned it up and repainted the stand. The id badge is included in the photos. Any help would be appreciated. I know it came from a machine shop in Charleston Wv, and that my uncle and grandfather had a spat over it. That is probably why my grandfather engraved his name on the drill.
Your 1514 drill stand appears in the 1949 catalog. Welcome to the Garage Journal.
Teethsmasher
Thank you sir that is indeed the first thing I've ever seen on this! The drill itself is a 514c model, I've cleaned it up as well and replaced the power chord. Its a Family Heirloom that I'll never get rid of but is always nice to finally get some information about it. And thank you for the welcome!
Half-fast eddie
Virginia
Could use a little help identifying this hand drill. The handle is marked 1980A but i don’t think this is correct, i think it has been added from a different drill.
Pretty sure the end of the handle has been trimmed, it was held in place with 2 nails driven from opposite sides and jammed tightly.
Here is a picture from the 1925 catalog, couple of differences: mine has a heart shaped frame just ahead if the handle, that doesn't look like the catalog. Mine does have the 2 speed knob on the side.
