Show your new tool arrivals
torqueman2002
Just get a cable tie gun. Pulls the zip tie tight and then flush cuts. You can adjust the tension of the gun before it cuts so you don't damage the cable.
Yes, they work great.
Also, these are a good alternative and less $$$.
potato
https://scontent-dft4-1.**.fbcdn.net/v/t34.0-12/27718344_942737825884951_1869480469_n.jpg?oh=bb0af25a15c27d84f02ee0275ff9478e&oe=5A7A4826 $50 all usa v^
https://scontent-dft4-1.**.fbcdn.net/v/t35.0-12/27747081_942737895884944_1118658386_o.jpg?oh=b2217a609c729e21ea39eb1b7bd3f72c&oe=5A7B8CBA $110 shll80a from a local pawn
-OSIS-
https://scontent-dft4-1.**.fbcdn.net/v/t35.0-12/27746776_942737892551611_1758180031_o.jpg?oh=fba6be2735ba13dedebfa944c3eae778&oe=5A7AFCF7 $110 shll80a from a local pawn
That’s a you **** deal :O
GTO
NJ,FL
fe7a3ff6a2c081929f1cf768a53f7bb4.jpgHot buy section got these off amazon luv the little 1/4 inch ratchet. Be able to get into super tight sections with that little guy.
I looked @ those ratchets on Amazon,just wondering if you have run into any issues with the heads being really thick.
Thanks
PR1Gneon
Sent from my SAMSUNG-SM-N920A using Tapatalk
Also bought the 3/8"4f2b08bdbf0d87e5fc18a7d8ca2a0db4.jpg
potato
i never liked those.ok if everything is wide open but a true pain in tight spots.
Odd-job
Found this torque adapter at my local harbor freight. Was initially bummed as the Pittsburgh Pro version was no longer available on the website so I thought it was discontinued. Glad they brought it back.
dodge610
North Canton Ohio
95733a19c96fd62230457ab3268ca5fa.jpgNewest addition to my shop had one go bad replacing with the craftsman professional.
quadrcr87
Travelers Rest, SC
Just arrived today on the big brown truck! Matches the 1/4 Williams USA I got last week. Now I really want the 3/8 drive. These things are solid!
BigBoreFan
KTC extra-long zero offset box wrenches
M160-17X19 (this one was a freebie, bank error in your favor sort of thing)
M160-14X17
M160-12X14
SK extra long 10mm wrench 88510
Armstrong 6pt wrenches
17mm Long Satin S52-317
14mm Full Polish 52-014
12mm Full Polish 52-012
Allen 17mmX19mm open end wrench 21117
SK 1/4 impact extension set 31160
SK 1/4 impact universal 32990
Where did you purchase the KTC's. I need an extra long zero offset.
OCD
Edmonton, Ab. Canada
My arms are bleeding just looking at that. For the sake of everyone that will be working in the same area as well as your own, spend the $5 on a pair of flush cutters for those zip ties.
Keep your arms and anything else away from my cables!! :willy_nil
I had a cheap pair of flush cutters that I used for a long time, then they somehow dropped 35 feet, hit the only piece of steel on the floor, and broke a tip... :(
I had been using my snap on 5" side cutters when I took those pics, but they don't cut the thread in the cable very well at all... The Knipex worked great for cutting, but they aren't flush either, and leave an edge on the ties...
I picked up a pair of channellock 758's today and like them so far, but still want you to stay away from my cables!!
OCD
Love the install. I hate seeing ugly cable routing when I look up.
Thank you!! Anytime I am working at a clients, I treat it as if I owned the place myself... This warehouse has taken 6000 feet of cable so far and the only place it can be seen from the ground is where it loops from a pipe to a beam... Not to many people will even notice that though!!
stonesfan68
Houston, TX
Ive broken a couple of Craftsman sockets using a 3/8 Snap-on flex ratchet and decided to upgrade my sockets.
16again
Boynton Beach, FL.
Arrived today. Built solid and feel decent in my hand. As others have said, heads are thick for sure. Selector switch remains to be seen if it needs to be trimmed or if it will be ok. :D
Picture looks fine on my computer but posts sideways...
L.Cheapo
View media item 80389
I really could have used this a few weeks ago. Couldn't get my big frozen hands in the tiny space around the handle-less carcass of an original battery in a late model Liberty. Nicely made in the USA.
BigBoreFan
Some new stuff
SK Screwdrivers, same as my old Craftsman Pro drivers.
Knipex Snap Ring pliers. I no longer despise snap rings. Much better than a flat blade screwdriver or my el cheapo Protos with broken tips.
Bondhus Metirc T-Handle Hex Keys for the workbench.
My first order from KC-Tools. Various German tools to test the waters. Love the Felo wooden handle. The Weras are nut drivers, 6mm and 8mm. That mini crowbar is a T45 Torx, massive.
And an inexpensive Impact set. It's not a full set, it has skips, but has the sizes I need. I work on motorcycles mostly, as a hobby, I rarely use impact drivers.
-OSIS-
Extension came in. Grabbed a maggot and a fixed head 3/8 ratchet.
PR1Gneon
Rubiman14
Snap-on guy showed up with some things I ordered 😁
And of course the obligatory drawer pic with some new tools
zendriver
Indiana
Earthquake XT 3/8" cordless ratchet.
Purchased to speed removal of auto parts because I wanted one.
turnthewrench 2.0
FL
Little Proto from Zoro. Needle nose pliers and 1/2" Impact U-Joint.
shanny19
PNW
I've spent the last 20 minutes reading nothing but bad reviews of that thing, and I still WANT one!
